controller | AP | conf
Hello Support Community,
Please guide me on best practise configuration on WLC | AP | Switches
Controller - 5508
L3 switch - Catalyst 4509
L2 switch - Cisco 2960
1 -  What is the configuration required on L3 switch connecting WLC
2  -   If I have 3 SSID then should I connect to 3 ports of WLC to L3 switch or single port
3  -   what is the configuration required on the L2 switch port connecting AP
4 -   What configuration is required on the AP to join the Controller, should be have static or dynamic IP  for AP
Thank You
JP
  • Getting Started with Wireless
VIP Purple
HI Jean,
You need to configure initial config..
http://www.xerunetworks.com/2012/05/cisco-5508-wlc-setup-and-initial-configuration/
http://ciscowlc.blogspot.de/2012/06/initial-configuration-for-cisco-wlc.html
Yes or No, but I will recommand to use only one port(Port 1).
L2 Swicth Config:
interface FasttEthernet0/xx
switchport access vlan 80
switchport mode access
*** In my example AP and WLC are in vlan 80.
You can configure like this on Layer 3 Swicth :
1. Create a DHCP pool from AP will get a IP via DHCP.
2. Connect WLC at right ports:
ip dhcp excluded-address 10.xx.80.1 10.xx.80.100
ip dhcp excluded-address 10.xx.80.115 10.xx.80.254
ip dhcp pool WirelessLAN
   network 10.xx.80.0 255.255.255.0
   default-router 10.xx.80.254
   option 43 ip 10.xx.80.1  -----> WLC IP addres
   lease 3
WLC Connection port config:
interface FastEthernet2/0/42
description *** WLAN Controller ***
switchport trunk allowed vlan 80,81,82
switchport mode trunk
speed 100
duplex full
Hope it helps.
Dont forget to rate helpful posts
Sandeep,  thank you.  Your input helps alot
  • Any initial configuration required on AP unpacked from a box
  • How the traffic flow from a wireless connected user ?  user--AP--switch--WLC----server or user--AP--switch---server
  • On WLC 5508 there is RP & SP ports -  what are these ports for ??
  • Is it recommended to have one port configured for Management ??
  • Is It recommended to have one dedicated port configured for Guest SSID
  • What is the best practise for Guest SSID. i.e dhcp on WLC or L3 switch /
  • Guest traffic should pass through Local Proxy bluecoat, possible to automate proxy IP and port entry in DHCP config ( guest get ip and proxy info with DHCP )
  • best practise to secure the WLC and AP registration
Hall of Fame Super Gold
Just make sure your DHCP Option 43 is configured.
RP stands for Redundant Port.  SP stands for Service Port.  Both ports are explained in the configuration guide.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-6/configuration/guide/b_cg76.html
Take the time and effor to read them because they will teach you A LOT.
This information should be explained in detail in the configuration guide (link posted above).
VIP Purple
HI jean,
No, You dont need to configure anything on AP(ZeroTouch Configurationg ). But make sure you have a DHCP pool on swicth from where AP can get IP address as well as the ip of the WLC.(Just check the last answer in point 4). Try to keep AP and WLC management in same subnet.
user-AP-Switch-WLC-Server. More ...:
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Borderless_Networks/Unified_Access/BYOD_Design_Guide/BYOD_Guest_Wireless_Access.html
RP is used for HA:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113681-high-availability-dg-00.html#port
Service Port:
This port is used exclusively for Out-of-Band management. It is the only port that is active when the controller is in boot mode (useful for troubleshooting). The service port does not support 802.1Q tagging so you must configure the switch port on the other side in access mode. It does not support a backup port and a default gateway in its configuration. This last fact means that you can reach it only if you are on the same subnet (as it will not have a route back) unless you configure static routes in the menu Controller -> Network Routes.
***The service port and the management interface must be on a different subnet.The service port is also not auto-sensing so you must use the correct straight-through or crossover Ethernet cable to communicate with the service port.
Normally I use only one port for management and all other purpose.(You can also use sperate ports...).
I have DHCP on WLC for guest access, or you can have on DHCP server.
If you have firewall (I dont know about bluecoat).
You can use authrize function WLC and add the mac of the AP in it. Then only that AP will join which have the mac address in the auth. list.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
Dont forget to rate helpful posts.
203
