Community Member
controller conflict
We have a subsidary network which has a wireless controller in use currently with many ap's attached to it.
The subsidary is planning to install another wireless controller in the same location as above. The problem is they want to use the same controller hostname as the existing one , although the ip address would be different.
I am not certain what effect this will have as both old & new controller will connect to the single core switch that they have.
How will this impact the users & what will happen to the new AP's that will be added to the new controller via the core switch.
Thanks in advance for all help.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
controller conflict
Hostname will not cause an issue because you have two different management IP addresses.  It'll just be the poor engineer to determine which WLC he/she is logged into.
controller conflict
controller conflict
You may have the same hostname on different controller in same subnet .. no problem..
hostname is not really necessary for the AP to join the WLC.. It will be just necessary to
have the IP address default gateway and controller IP address configured to have the AP
registered on the WLC.
VIP Purple
Re: controller conflict
Keep in mind if you want  to configure High Availability for APs it will not allow you to configure same WLC name as primary, secondary or tertiary.
Primary, Secondary & Tertiary controller should have unique names when configuring this.
So better to advise them not to use same hostname for multiple controllers.
Rasika
*** Pls rate all useful responses ***
Community Member
controller conflict
Thanks.
So , if we have two controllers in the same network with different ip address, how will the AP's register to the network & which controller will take precedence?
VIP Purple
You can read below "AP Failover" & "AP Registration" posts to get an idea how this work.
1. http://mrncciew.com/2013/04/07/ap-failover/
2. http://mrncciew.com/2013/03/17/ap-registration/
As I stated early, you cannot configure Primary,Secondary & Tertiary (High Availability feature) for a AP  if your controllers have same name. So you will be stuck if you want to nominate both primary & secondary controller for your APs in this environment (assume both controllers having same name).
Without this feature AP can go for either controller & can register (but you do not have any control which ap goes to where). In the AP registration WLC name does not play any role(but in failover it will), so as longs as AP learn a WLC IP it can send a join requests & depends on who is responding, AP will go and register to that WLC.
Rasika
**** Pls rate all useful responses ****
Hall of Fame Super Silver
I've been sort of following this and just can't understand why they can't be convinced to rename the other WLC or have different names maybe with 01 and 02 as the suffix. Everyone has put in their opinions and facts, but if you plan on using Prime or a monitoring tool, that's where you might also run into issues. I'm guessing DNS isn't used either on the wlc's? I would just push for different hostnames as I don't think your switches have the same hostnames.
-Scott
Community Member
controller conflict
Thanks Scott & everyone for the inputs.
Yes, i would tell them the only way out is to change the suffix.
Thanks again!
243
