Converting 3600 from CAPWAP to Autonomious for Survey
Hi all,
how can I convert a 3602 AP from CAPWAP to IOS from Survey Purpose?
Willem
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Pretty simple... here are some links and videos on how to do that:
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott
-Scott
Hi All,
I got it to work this way:
I used this Link:
Used this DHCP Server : http://www.dhcpserver.de/dhcpsrv.htm
DHCP Server set to LAN port on Laptop, with one Address
LAN Port Laptop connected to LAN Port AP
Used 3CDaemon as TFTP Server
For my 3602i AP I used this Image (without renaming)
ap3g2-k9w7-tar.152-2.JB.tar
Now the next step is to set this AP for Site Survey.
Re: Converting 3600 from CAPWAP to Autonomious for Survey
Glad you got it converted.
-Scott
This process was a pita for me.
Unless you can join it to a controller the archive download-sw command didn't work because the AP keep reDHCPing in the middle of the download.
If you can run the command while it is joined to a controller that is the best.
If not you may need to do it the hard way
https://supportforums.cisco.com/docs/DOC-14636
Long read on my issues with this process.
https://supportforums.cisco.com/message/3829516#3829516
CCNP - Wireless
CWNA and CWAP
CCNP - Wireless CWNA and CWAP
312
