Converting AIR-AP1231G-A-K9 to lightweight mode
Hi Everyone,
I have an issue with Cisco AP AIR-AP1231G-A-K9 after converted to Lightweight mode. I am using WLC 2106 with version code of 7.0.98.0 but after successfull conversion from autonomous mode to lightweight mode the, the AP is not getting associated to WLC. It shows up for a one or two seconds under WLC and then again disappers. This AP has raido AIR-MP31G which i think is supported for converting it to lightweight mode.
Please see below the log of the upgrade utility after convertign to lightweight mode.
2013/07/02 18:45:38 DEBUG            34.109.56.4            Validating IP address
2013/07/02 18:45:38 DEBUG            34.109.56.4            Opening a telnet connection to the AP
2013/07/02 18:45:40 INFO            34.109.56.4            User  has  Full privilege
2013/07/02 18:45:40 INFO            34.109.56.4            Getting  AP Name
2013/07/02 18:45:40 DEBUG            34.109.56.4            Verify if APs image is 12.3(07)JA or greater
2013/07/02 18:45:41 INFO            34.109.56.4            AP  has 12.3(7)JA Image or greater
2013/07/02 18:45:41 DEBUG            34.109.56.4            Identifying the AP Type
2013/07/02 18:45:41 INFO            34.109.56.4            Term Length configured.
2013/07/02 18:45:41 INFO            34.109.56.4            Upgrade Tool supported AP
2013/07/02 18:45:41 DEBUG            34.109.56.4            Check whether AP has supported Radio
2013/07/02 18:45:41 INFO            34.109.56.4            AP has Supported Radio
2013/07/02 18:45:41 DEBUG            34.109.56.4            Verifying Station Role
2013/07/02 18:45:42 INFO            34.109.56.4            Station role is  Root AP
2013/07/02 18:45:42 DEBUG            34.109.56.4            Check whether AP has  MIC Certificate
2013/07/02 18:45:42 INFO            34.109.56.4            MIC is already configured in the AP
2013/07/02 18:45:42 DEBUG            34.109.56.4            Getting Ethernet MAC address
2013/07/02 18:45:42 INFO            34.109.56.4     Hardware is PowerPC405GP Ethernet, address is 0007.0e5b.8e9d (bia 0007.0e5b.8e9d)
2013/07/02 18:45:42 DEBUG            34.109.56.4            Getting the Radio Status
2013/07/02 18:45:42 DEBUG            34.109.56.4            Entering Configuration mode
2013/07/02 18:45:42 INFO            34.109.56.4            Inside Shutdown function
2013/07/02 18:45:45 INFO            34.109.56.4            Shutdown the Dot11Radio0
2013/07/02 18:45:45 DEBUG            34.109.56.4            Getting Current System Time
2013/07/02 18:45:46 INFO            34.109.56.4            Updating the AP with Current System Time
2013/07/02 18:45:46 DEBUG            34.109.56.4            Entering Configuration mode
2013/07/02 18:45:47 DEBUG            34.109.56.4            Executing show run
2013/07/02 18:45:47 INFO            34.109.56.4            Saving the configuration into memory
2013/07/02 18:45:47 INFO            34.109.56.4            Getting  AP Name
2013/07/02 18:45:47 DEBUG            34.109.56.4            Loading the LWAPP Recovery Image on to the AP
2013/07/02 18:48:10 DEBUG            34.109.56.4            Checking the Upload Status
2013/07/02 18:48:12 INFO            34.109.56.4            Successfully Loaded the LWAPP Recovery Image on to the AP
2013/07/02 18:48:12 INFO            34.109.56.4            Executing Write Erase Command
2013/07/02 18:48:18 INFO            34.109.56.4            Flash contents are logged
2013/07/02 18:48:20 INFO            34.109.56.4            Logged nvram: contents
2013/07/02 18:48:22 INFO            34.109.56.4            Logged crypto trust-points
2013/07/02 18:48:24 INFO            34.109.56.4            Logged crypto certificates
2013/07/02 18:48:26 INFO            34.109.56.4            Terminal length set to Zero
2013/07/02 18:48:32 INFO            34.109.56.4            Loading 34.109.56.4env_2July2013_184830.log from 34.108.7.50 (via BVI1): !
2013/07/02 18:48:32 INFO            34.109.56.4            Reloading the AP
2013/07/02 18:48:36 INFO            34.109.56.4            Successfully executed the Reload command
2013/07/02 18:48:36 DEBUG            34.109.56.4            Closing the Telnet Session
The Command output form WLC please see bellow
(Cisco Controller) >show ap join stats summary 00:07:0e:5b:8e:9d
Is the AP currently connected to controller................ Yes
Time at which the AP joined this controller last time...... Not applicable
Type of error that occurred last........................... Lwapp configuration        request rejected
Reason for error that occurred last........................ Ignoring config stat        us as mac address is not present in database
Time at which the last join eror occurred.................. Jul 03 02:43:25.677
(Cisco Controller)
  • Getting Started with Wireless
Hall of Fame Super Silver
Re: Converting AIR-AP1231G-A-K9 to lightweight mode
Well with older APs you might need to enter the SSC before it will join the WLC. Take a look at this link to obtain the SSC and add it to the WLC. The link
Also goes over other reasons that an ap fails to join.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072d9a1.shtml#cause4
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
Hi Scott, its says in the output given abvoe from upgrade tool "MIC is already configured in the AP" which meam thers is no need for SSC?
Gold
On top of what Scot said, below document will have more detials how can this issue be fixed.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00806a426c.shtml
Hope that helps
Najaf
Please rate when applicable or helpful !!!
This was the command detailed output from WLC
(Cisco Controller) >show ap join stats detailed 00:1d:45:eb:f6:80
Discovery phase statistics
- Discovery requests received.............................. 114
- Successful discovery responses sent...................... 76
- Unsuccessful discovery request processing................ 0
- Reason for last unsuccessful discovery attempt........... Not applicable
- Time at last successful discovery attempt................ Jul 03 04:19:19.791
- Time at last unsuccessful discovery attempt.............. Not applicable
Join phase statistics
- Join requests received................................... 37
- Successful join responses sent........................... 37
- Unsuccessful join request processing..................... 0
- Reason for last unsuccessful join attempt................ Not applicable
- Time at last successful join attempt..................... Jul 03 04:19:18.831
- Time at last unsuccessful join attempt................... Not applicable
Configuration phase statistics
- Configuration requests received.......................... 74
- Successful configuration responses sent.................. 0
- Unsuccessful configuration request processing............ 37
- Reason for last unsuccessful configuration attempt....... Ignoring config status as mac address is not present in database
- Time at last successful configuration attempt............ Not applicable
--More-- or (q)uit
- Time at last unsuccessful configuration attempt.......... Jul 03 04:19:19.638
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Not applicable
Last join error summary
- Type of error that occurred last......................... Lwapp configuration request rejected
- Reason for error that occurred last...................... Ignoring config status as mac address is not present in database
- Time at which the last join error occurred............... Jul 03 04:19:19.638
        Ethernet Mac : 00:07:0e:5b:8e:9d  Ip Address : 34.109.56.10
This doesn't really tell us much....  You need to post the output from the console of the AP.  POst the output when you power cycle the AP.  That will show you also if the SSC is there or not.  Did you go through the troubleshooting link?
Scott
It will also help to capture
debug mac-address < ap mac address >
debug capwap events enable
debug capwap errors enable
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
This problem have been fixed, it was regulatory domain issue. After adding the proper country code the probelm got fixed.
1186
