Community Member
Converting an AP to LWAPP using WCS
I am trying to migrate from an AP via the WCS and handed me the following log
START: Detailed logging started at -> 09.21.2010_19.12.09
INFO: TELNET to device done.
INFO: Privilege level is equal to 15.
INFO: Setting vty line completed.
INFO: Dumped Environmental variables.
INFO: AP is supported for Upgrade process
INFO: IOS version is greater than or equal to 12.3(7)JA.
INFO: AP has MIC installed already.
INFO: Station role is root.
INFO: DNS and Domain name configured.
INFO: Mac address of device is 00:23:33:97:74:62
INFO: Completed Dot11Radio0 shutting.
INFO: Device set up done and time configured on device.
INFO: Run-config dumped.
INFO:  Gateway
INFO: Hostname HotelC4
INFO: Starts loading recovery image, takes time based on link speed.
ERROR: Device Response :: examining image...
%Error opening  (Permission denied)archive download: takes 0 seconds
ERROR: Image Loading FAILURE.
INFO: Un-shut radio 1 done.
END: Migration Process Failure: Image Loading Failure.
The AP is a 1121 and I have the IOS file-C1100-rcvk9w8 tar.124-21a.JA2
tftp server field put the ip address of my PC
in the field file path  C:/
in the field file   C1100-rcvk9w8 tar.124-21a.JA2
please help need to know that I'm doing wrong step
Re: Converting an AP to LWAPP using WCS
Do you have an 802.11g radio in your ap?
Community Member
Estimate, has the following characteristics AP1121
00:23:33:97:74:62 802.11b/gUnassignedN/A0EnabledN/AUpOK
Software Version12.3(8)JEB
Inventory Information
AP TypeAutonomous
AP ModelAIR-AP1121G-A-K9
H-REAP Mode SupportedNo
Unique Device Identifier (UDI)
DescriptionCisco Aironet 1100 Series (IEEE 802.11g) Access Point
Product IdAIR-AP1121G-A-K9
Version IdV04
Serial NumberFTX1315V08Q
