could not resolve CISCO-LWAPP-CONTROLLER
Hi..
I have AP Cisco Aironet 1250.  I want upgrade to LWAPP. AP using static IP address. When AP try to joinm error message displayed "DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLLER".
Loading file /c1250...
extracting info (292 bytes)
Image info:
    Version Suffix: k9w8-.124-10b.JDD
    Image Name: c1250-k9w8-mx.124-10b.JDD
    Version Directory: c1250-k9w8-mx.124-10b.JDD
    Ios Image Size: 4352512
    Total Image Size: 4352512
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: C1250
    Wireless Switch Management Version: 4.2.207.0
Extracting files...
c1250-k9w8-mx.124-10b.JDD/ (directory) 0 (bytes)
extracting c1250-k9w8-mx.124-10b.JDD/c1250-k9w8-mx.124-10b.JDD (3956889 bytes)
%LWAPP-5-!CHANGED: LWAPP changed state to JOIN
%LWAPP-5-CHANGED: LWAPP changed state to IMAGE
Error messages:
*Jun 30 09:46:16.491: %LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER
*Jun 30 09:46:16.491: %LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLLER
*Jun 30 09:46:16.491: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Jun 30 09:46:16.651: %LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER
*Jun 30 09:46:16.651: %LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLLER
*Jun 30 09:46:16.651: Logging LWAPP message to 255.255.255.255.
Any help?
Thanks.
Hall of Fame Super Gold
Re: could not resolve CISCO-LWAPP-CONTROLLER
Do you have a DNS entry for CISCO-LWAPP-CONTROLLER and CISCO-CAPWAP-CONTROLLER?
This is my DHCP configuration,
ip dhcp pool AccessPoint
   network 172.21.84.128 255.255.255.128
   default-router 172.21.84.129
   dns-server 172.21.84.36
   domain-name CISCO-LWAPP-CONTROLLER.mydomain.com
   option 60 ascii "Cisco AP c1250"
   option 43 hex f104ac100019
is it correct?
You configuration is not correct. You can remove the line ‘domain-name CISCO-LWAPP-CONTROLLER.mydomain.com’ or replace it with ‘domain-name mydomain.com’ and configure the DNS server with both "CISCO-LWAPP-CONTROLLER.mydomain.com" and "CISCO-CAPWAP-CONTROLLER.mydomain.com" pointing to 172.16.00.25.
I suggest that you remove this line and forget about DNS and go for DHCP option 60 and 43 as you already have configured. You do not need both the DNS configuration and DHCP option 43.
Since you have configured ‘option 60 ascii "Cisco AP c1250"’ and ‘option 43 hex f104ac100019’ then your 1250s should try to associate with the controller 172.16.00.25.
Please post more of the syslog and look for events regarding DHCP option 43.
Is the address 172.16.00.25 for the WLC correct?
André
I delete "domain-name CISCO-LWAPP-CONTROLLER.mydomain.com" at DHCP pool, try to reset LWAP configuration, but I
received wrong controller IP address obtained through DNS. LWAP restarted, then I got error message "no more AP
manager IP addresses remain".
Then I try to add this command to LWAP "lwapp ap controller ip address 172.16.0.25", new image downloaded, LWAP
restarted. "Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET CONFIG RESPONSE".
%LWAPP-3-CLIENTEVENTLOG: Controller address 172.16.0.25 obtained through DHCP
%LWAPP-3-CLIENTEVENTLOG: Did not get log server settings from DHCP.
%LWAPP-3-CLIENTEVENTLOG: Did not get any DNS options from DHCP.
Now I will try to configure CISCO-LWAPP-CONTROLLER pointing to 172.16.0.25 at DNS server.
The address 172.16.00.25 for the WLC is correct.
25639
