Country code for Japan LWAPP on 7500 WLC
Hi friends,
I have a setup with a 7500 WLC and 3602-Q and 1142-P model access points.
The 3602-Q ones are working ok, however on those 1142-P models sometime some users cannot connect.
They are using various models of laptops, so I am not sure which one works and which one don't.
I also noticed the 1142-P has auto chosen its country code as J4 Japan (4Q).
I suspect this is the problem.
Do you guys know which country code to enable for this AP?
AIR-LAP1142N-P-K9
I have few country options in WLC. So far have only enabled Japan and J4
Japan 2(P) - disabled
Japan 3(U) - disabled
Japan 4(Q) - enabled
Japan (JP) - enabled
Going to enable 2(P) and test.
1 ACCEPTED SOLUTION
VIP Purple
Hi ,
your AP have AIR-LAP1142N-P-K9.(P Reguletry domain).
Only One laptop is diconnecting or may others have the same problem of disconnection??
You can enable 2P mode on WLC and test, if still problem persists then plz paste the debug output from AP.
Dont forget to rate helpful posts.
VIP Purple
Hi ,
Re: Country code for Japan LWAPP on 7500 WLC
Yes thanks Sandeep, activating 2P worked on these models. More clients can login now. Used to be clients with newer laptop were not able to login.
334
