se
Create 2 IP addresses on one Cisco AP per vlan?
Hallo,
to get it simple -
I have only one switch with following equipement attached:
1 x AP1130AG,
1 x WLSE Express,
1 x DHCP/DNS-Server for 10.0.0.0/24 subnet,
1 x DHCP/DNS-Server for 192.168.2.0/24 subnet.
The AP, WLSE and the DHCP-/DNS-Server (192.168.2.0/24) are in the native vlan 1.
But the AP is also with the second DHCP-/DNS-Server in vlan 2.
Could get the AP two seperate IP-addresses per vlan? When not how I have to design the network? - With routing?
I am happy when somebody is able to help.
Sincerely
se
1 REPLY
Silver
Re: Create 2 IP addresses on one Cisco AP per vlan?
Hi se
This is how I do it (I don't have WLSE):
- Create a ssid per vlan in the AP.
- Configure switch to AP connection as a trunk.
- If needed, configure helper addresses in switch.
If you need routing between VLANs, you will need a router, afaik AP cannot do it.
277
