CT2504 and AP1602 slow wireless conn
I am using an 1602i access point for my company's wlan. The adapter that I use for the computers is Cisco Linksys AE3000 (which supports up to 450 Mbps). However, the wireless speed does not exceed 144 Mbps even though the computers are very close to the ap..
Doesn't the ap theoretically support up to 300 Mbps speed? Is there anything that I need to change to make it possible?
2 ACCEPTED SOLUTIONS
Your access point is 3x3 MIMO capable just like your NIC card. I would guess you don't have channel bonding enabled yet thus your data rate at MCS15 is 144.
VIP Purple
Re: CT2504 and AP1602 slow wireless conn
You can verify what rate your client is connecting using the below WLC CLI command
(WLC) >show client detail should show you the clent connected MCS rate
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Power Save....................................... OFF
Current Rate..................................... m15
Here is a snapshot of these MCS data rates. 1600 AP support upto 2-Streams and maximum you can get is 300Mbps. (if you have 2600 or 3600 it support upto 3 streams where you can get upto 450Mbps). As vlad mentioned you need to use channel bonding (ie 40MHz) with short guard interval (ie 400ns)
You can find the above Ciscolive presentation material from below link (you can singup free for ciscolive365.com & can access these material)
https://www.ciscolive365.com/connect/sessionDetail.ww?SESSION_ID=7789&backBtn=true
Rasika
**** Pls rate all useful responses ****
VIP Purple
Rasika
Fixed it by changing the DCA settings. Thanks!
646
