Customised Captive Portal - C5760
I'm trying to use customised captive portal for C5760 controller.
After uploading the customised page, the captive portal still points back to http://virtual ip/login.html.
Have anyone successfully uploaded and managed to used customised captive portal page ?
I tried to used the path setting for the customised page but everytime it reverts back to the blank fill in field.
Appreciate if anyone could shed some headlights into this.
Thank you.
Re: Customised Captive Portal - C5760
Raymond am
Not quite sure if i understood the question. Can you explain in more detail?
I have uploaded the custimosed captive portal but the C5760 controller still uses the default login page.
I have also tried to change the path of the customised login page, but everytime the contoller revert back to the default login page also.
How do I change the default path of the login page to my customised login page ?
mind sharing the show run ? and flash contents? the pages are locally hosted in the flash correct?
Attached please find the show run output.
Yes, I have uploaded the pages to the controller.
Building configuration...
Current configuration with default configurations exposed : 176320 bytes
! Last configuration change at 15:59:50 MY Thu Aug 29 2013 by admin
version 15.0
parser cache
parser config partition
parser command serializer
parser maximum utilization 100
parser maximum latency 40
downward-compatible-config 15.0
no service log backtrace
no service config
no service exec-callback
no service nagle
service slave-log
no service slave-coredump
no service pad to-xot
no service pad from-xot
no service pad cmns
no service pad
no service telnet-zeroidle
no service tcp-keepalives-in
no service tcp-keepalives-out
no service exec-wait
no service linenumber
no service internal
no service scripting
service compress-config
service prompt config
no service old-slip-prompts
no service pt-vty-logging
no service disable-ip-fast-frag
no service sequence-numbers
service counters max age 0
service dhcp
no service call-home
hostname C5760-WC01
boot-start-marker
boot-end-marker
shell processing
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
--More--                           no logging discriminator
logging exception 4096
no logging count
no logging message-counter log
no logging message-counter debug
logging message-counter syslog
no logging snmp-authfail
no logging userinfo
logging buginf
logging queue-limit 100
logging queue-limit esm 0
logging queue-limit trap 100
logging buffered 16384 debugging
logging reload message-limit 1000 notifications
no logging persistent
logging rate-limit console 10 except errors
logging console guaranteed
logging console debugging
logging monitor debugging
logging cns-events informational
logging on
enable password Cisco123
username admin privilege 15 password 0 Cisco123
username root privilege 15 password 0 Cisco123
user-name guest
creation-time 1375852861
privilege 15
password 0 guest
type network-user description Guest guest-user lifetime year 0 month 11 day 23 hour 23 minute 59 second 29
no software auto-upgrade source url
no software auto-upgrade enable
spd extended-headroom 10
spd headroom 100
spd enable
aaa new-model
aaa local authentication default authorization default
aaa group server radius Dot1x_Radius
server name College_Radius
cache expiry 24 enforce hours
aaa authentication attempts login 3
aaa authentication login default local
aaa authentication login local_webauth local
aaa authentication dot1x Dot1x_Authentication group Dot1x_Radius
aaa authorization network default local
aaa authorization network webauth_radius group Dot1x_Radius
aaa authorization network local_webauth local
aaa authorization credential-download default local
aaa accounting jitter maximum 300
port 1645
--More--                           !
port 1700
aaa session-id common
aaa memory threshold authentication reject 3
aaa memory threshold accounting disable 2
ipc holdq threshold upper 20
ipc holdq threshold lower 1
ipc header-cache permanent 6000 100
ipc buffers max-free 1200
ipc buffers min-free 400
ipc buffers permanent 1200
clock timezone MY 8 0
clock save interval 0
clock initialize nvram
cef table consistency-check IPv4 type lc-detect count 71 period 60
cef table consistency-check IPv4 type scan-lc-rp count 71 period 60
cef table consistency-check IPv4 type scan-rp-lc count 71 period 60
cef table consistency-check IPv4 type scan-rib-ios count 1000 period 60
cef table consistency-check IPv4 type scan-ios-rib count 1000 period 60
no cef table consistency-check IPv4 data-checking
no cef table consistency-check IPv4 error-message
cef table consistency-check IPv4 auto-repair delay 10 holddown 300
cef table consistency-check IPv6 type lc-detect count 26 period 60
cef table consistency-check IPv6 type scan-lc-rp count 26 period 60
cef table consistency-check IPv6 type scan-rp-lc count 26 period 60
cef table consistency-check IPv6 type scan-ios-rib count 1000 period 60
no cef table consistency-check IPv6 data-checking
no cef table consistency-check IPv6 error-message
cef table consistency-check IPv6 auto-repair delay 10 holddown 300
cef table vrf tree IPv4 type MTRIE short-mask-protection 4 stride-pattern 8-8-8-8 hardware-api-notify off
cef table vrf tree IPv6 type RTREE
cef table output-chain build favor default
cef table rate-monitor-period 5
cef table download recursive-dependents priority 1
cef table download default-route priority 1
cef table download connected-route priority 2
cef table download receive-route priority 2
cef table download route-in-vrf priority 3
cef table download catch-all priority 4
no authentication logging verbose
authentication command bounce-port ignore
authentication command disable-port ignore
authentication critical recovery delay 100
access-session mac-move deny
eap profile LOCAL_eap
method peap
method leap
method tls
method fast
nmsp notification interval attachment 30
nmsp notification interval location 30
nmsp notification interval rssi clients 2
nmsp notification interval rssi rogues ap 2
--More--                           nmsp notification interval rssi rogues client 2
nmsp notification interval rssi rfid 2
passwd encryption on
passwd key obfuscate
no cisp enable
ip subnet-zero
ip source-route
ip arp poll queue 1000
ip arp poll rate 1000
no ip arp proxy disable
ip arp gleaning tftp
ip arp gleaning udp
ip arp incomplete retry 20
ip arp incomplete entries 5000
ip arp incomplete enable
ip arp inspection log-buffer entries 32
ip arp inspection log-buffer logs 5 interval 1
ip sticky-arp
ip gratuitous-arps non-local
ip icmp redirect subnet
ip spd queue max-threshold 74
ip spd queue min-threshold 73
ip verify drop-rate compute window 300
ip verify drop-rate compute interval 30
ip verify drop-rate notify hold-down 300
ip cef optimize neighbor resolution
no ip cef accounting
ip cef load-sharing algorithm universal AF288640
ip dhcp-client broadcast-flag
ip dhcp-client default-router distance 254
ip device tracking probe count 3
ip device tracking probe interval 30
ip device tracking probe use-svi
ip device tracking probe delay 0
ip device tracking
ip accounting-threshold 512
ip dhcp relay information policy replace
ip dhcp relay information check
ip dhcp relay override giaddr link-selection
ip dhcp use class
ip dhcp use vrf connected
ip dhcp binding cleanup interval 120
no ip dhcp snooping information option allow-untrusted
no ip dhcp snooping database
ip dhcp snooping database write-delay 300
ip dhcp snooping database timeout 300
ip dhcp snooping verify mac-address
ip dhcp snooping verify no-relay-agent-address
no ip dhcp snooping wireless bootp-broadcast enable
ip dhcp conflict logging
ip dhcp ping packets 2
ip dhcp ping timeout 500
ip igmp ssm-map query dns
--More--                           ip igmp snooping report-suppression
no ip igmp snooping tcn query solicit
ip igmp snooping tcn flood query count 2
ip igmp snooping robustness-variable 2
ip igmp snooping last-member-query-count 2
ip igmp snooping last-member-query-interval 1000
ip igmp snooping querier version 2
ip igmp snooping querier query-interval 60
ip igmp snooping querier max-response-time 10
ip igmp snooping querier timer expiry 120
ip igmp snooping querier tcn query count 2
ip igmp snooping querier tcn query interval 10
no ip igmp snooping querier
ip igmp snooping
ipv6 hop-limit 64
ipv6 icmp error-interval 100 10
ipv6 nd cache expire 14400
ipv6 nd nsf convergence 120
ipv6 nd nsf throttle 512
ipv6 nd nsf dad suppress 60
ipv6 nd nud limit 256
ipv6 nd reachable-time 0
ipv6 nd ns-interval 0
ipv6 nd resolution data limit 16
ipv6 nd dad time 0
ipv6 nsf-converge 10
ipv6 traffic interface-statistics
ipv6 cef optimize neighbor resolution
ipv6 cef load-sharing algorithm universal AF288640
ipv6 mld snooping listener-message-suppression
no ipv6 mld snooping tcn query solicit
ipv6 mld snooping tcn flood query count 2
ipv6 mld snooping robustness-variable 2
ipv6 mld snooping last-listener-query-count 2
ipv6 mld snooping last-listener-query-interval 1000
no ipv6 snooping logging packet drop
ipv6 dhcp ping packets 0
ipv6 dhcp server join all-dhcp-servers
ntp max-associations 100
qos wireless-default-untrust
vtp domain Rafflesia
vtp mode transparent
call-home
alert-group configuration
alert-group diagnostic
alert-group environment
alert-group inventory
alert-group syslog
rate-limit 20
profile "CiscoTAC-1"
  no active
  destination preferred-msg-format xml
  destination message-size-limit 3145728
  no destination transport-method http
  destination transport-method email
  destination address email callhome@cisco.com
--More--                             destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  subscribe-to-alert-group diagnostic severity minor
  subscribe-to-alert-group environment severity warning
  subscribe-to-alert-group inventory
  subscribe-to-alert-group syslog severity major pattern ".*"
  subscribe-to-alert-group configuration periodic monthly 1 9:15
  subscribe-to-alert-group inventory periodic monthly 1 9:00
no mab request format attribute 32
no mab logging verbose
xdr multicast-group mode individual
xdr multicast-group internal split threshold 7000
xdr multicast-group internal issu-slots-split
captive-portal-bypass
setup express
scripting tcl low-memory 379198184
crypto pki trustpoint TP-self-signed-2628871826
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2628871826
revocation-check none
rsakeypair TP-self-signed-2628871826
crypto pki certificate chain TP-self-signed-2628871826
certificate self-signed 01
  30820249 308201B2 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32363238 38373138 3236301E 170D3133 30383238 31353335
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36323838
  37313832 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A67F 0E4FE2C8 835AB925 3C112DB2 2B987A16 22A18D03 FDCF4250 88CDBFC5
  270A1617 2A9C4913 031B214A 6128C845 BE993925 B5347047 A3418690 201F487D
  9FE0E6AE DB33C25E 41ED84AF 438E8DBF D5F9F3A7 D26D372E 626C1C94 4670D082
  A27D856C F539DABD 9D39DA3F 9FB7004F 03241F40 E8F065F2 26AAEC71 241C721B
  32570203 010001A3 71306F30 0F060355 1D130101 FF040530 030101FF 301C0603
  551D1104 15301382 11525043 4C47312D 43353736 302D5743 3031301F 0603551D
  23041830 16801495 A2C13C98 CF8CE589 BB93DB8B 4081BA68 E704D630 1D060355
  1D0E0416 041495A2 C13C98CF 8CE589BB 93DB8B40 81BA68E7 04D6300D 06092A86
  4886F70D 01010405 00038181 00842BF1 8B330CB5 E719C20C 81F655AB 4D7EA309
  7FE6FD0B 4D5FEDBA 5D56C6F8 02ACB5C0 09AAAB18 342E274A 022C669F 01AB7430
  C6BB1831 DF10DC97 B63B7104 CB8CA397 AB86018F C57810E1 2292ABBB B89390A2
  208CC941 2E359F2F D8618D7D 0833EDD8 3C86DBBB FA56318F ECB1EBAC 2298C5F1
  25980487 BE01BEA7 97403E6F C8
            quit
dot1x system-auth-control
no dot1x logging verbose
dot1x supplicant force-multicast
dot1x supplicant controlled transient
no dot1x critical eapol
system fnf bytes-count layer2
location algorithm rssi-average
location expiry calibrating-client 5
location expiry client 5
location expiry rogue-aps 5
location expiry tags 5
location notify-threshold client 0
--More--                           location notify-threshold rogue-aps 0
location notify-threshold tags 5
location rssi-half-life calibrating-client 0
location rssi-half-life client 0
location rssi-half-life rogue-aps 0
location rssi-half-life tags 0
location rfid timeout 1200
no location rfid vendor-name pango
location prefer static weight 0
location prefer lldp-med weight 2
location prefer cdp weight 1
diagnostic event-log size 500
diagnostic bootup level minimal
no diagnostic monitor syslog
diagnostic monitor interval switch 1 test DiagThermalTest 00:01:30 0 0 cardindex 5
diagnostic monitor interval switch 1 test DiagFanTest 00:01:30 0 0 cardindex 5
diagnostic monitor interval switch 1 test DiagScratchRegisterTest 00:01:30 0 0 cardindex 5
diagnostic monitor threshold switch 1 test DiagThermalTest failure count 5 cardindex 5
diagnostic monitor threshold switch 1 test DiagFanTest failure count 5 cardindex 5
diagnostic monitor threshold switch 1 test DiagScratchRegisterTest failure count 5 cardindex 5
diagnostic monitor switch 1 test DiagThermalTest cardindex 5
diagnostic monitor switch 1 test DiagFanTest cardindex 5
diagnostic monitor switch 1 test DiagScratchRegisterTest cardindex 5
port-channel load-balance src-dst-ip
lacp system-priority 32768
memory check-interval 60
memory statistics history table 24
memory validate-checksum 60
memory lite
memory chunk siblings threshold 10000
service-template webauth-global-inactive
inactivity-timer 3600
file verify auto
spanning-tree mode mst
no spanning-tree dispute
spanning-tree transmit hold-count 6
no spanning-tree optimize bpdu transmission
spanning-tree queue maxsize 12288
spanning-tree etherchannel guard misconfig
spanning-tree pathcost method short
spanning-tree mst configuration
name College
revision 1
instance 1 vlan 10-12, 16, 24-26
instance 2 vlan 30-33
instance 3 vlan 36
instance 4 vlan 50-51
instance 5 vlan 98-99
--More--                           spanning-tree mst hello-time 2
spanning-tree mst forward-time 15
spanning-tree mst max-age 20
spanning-tree mst max-hops 20
issu set rollback-timer 2700
hw-switch switch 1 logging onboard message level 3
process-max-time 50
parameter-map type webauth global
virtual-ip ipv4 172.16.16.16
custom-page login device flash:webauth_login.html
parameter-map type webauth College_Guest_Web
type webauth
timeout init-state min 1
max-http-conns 200
custom-page success device flash:webauth_success.html
custom-page failure device flash:webauth_fail.html
custom-page login expired device flash:webauth_expire.html
vlan group College-Group vlan-list 10-99
vlan 10
name Academic_Staff
vlan 11
vlan 12
name Parent
vlan 16
name Student
vlan 24
name Guest
vlan 25
name Account_Department
vlan 26
name HR_Department
vlan 33
vlan 98
name Network_Admin
vlan 99
name Network_Management
no ip finger
no ip tcp selective-ack
no ip tcp timestamp
ip tcp delayed-ack
ip tcp chunk-size 0
--More--                           ip tcp mss 0
ip tcp window-size 4128
ip tcp queuemax 20
ip tcp synwait-time 30
no ip tcp path-mtu-discovery
ip tcp async-mobility server
ip telnet tos C0
ip telnet quiet
ip telnet hidden hostnames
ip telnet hidden addresses
no ip telnet comport enable
ip telnet comport flow level 16
ip telnet comport receive window 4128
ip telnet comport disconnect delay 0
ip ftp passive
no ip tftp claim-netascii
ip ssh time-out 120
ip ssh authentication-retries 3
ip ssh break-string ~break
ip ssh dh min size 1024
ip rcmd domain-lookup
class-map match-any non-client-nrt-class
  match non-client-nrt
buffers element permanent 500
buffers element minimum 100
buffers fastswitching permanent 384
buffers fastswitching max-free 1024
buffers fastswitching min-free 128
buffers fastswitching initial 0
buffers small permanent 600
buffers small max-free 1250
buffers small min-free 100
buffers small initial 0
buffers middle permanent 450
buffers middle max-free 1000
buffers middle min-free 50
buffers middle initial 0
buffers big permanent 450
buffers big max-free 1500
buffers big min-free 25
buffers big initial 0
buffers verybig permanent 10
buffers verybig max-free 300
buffers verybig min-free 0
buffers verybig initial 0
buffers large permanent 10
buffers large max-free 30
buffers large min-free 0
buffers large initial 0
buffers huge permanent 5
buffers huge max-free 13
buffers huge min-free 0
buffers huge size 18024
buffers huge initial 0
no buffers tune automatic
--More--                           !
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip load-sharing per-destination
ip cef accounting non-recursive internal
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp last-member-query-interval 1000
ip igmp last-member-query-count 2
ip igmp query-max-response-time 10
ip igmp version 2
ip igmp query-interval 60
ip igmp tcn query count 2
ip igmp tcn query interval 10
load-interval 300
shutdown
negotiation auto
ipv6 nd dad attempts 1
ipv6 nd prefix framed-ipv6-prefix
ipv6 nd nud igp
ipv6 nd ra lifetime 1800
ipv6 nd ra interval 200
  ipv6 redirects
  ipv6 unreachables
snmp trap link-status
cdp tlv location
cdp tlv server-location
cdp tlv app
arp arpa
arp timeout 14400
spanning-tree port-priority 128
spanning-tree cost 0
hold-queue 75 in
hold-queue 0 out
no bgp-policy accounting input
no bgp-policy accounting output
no bgp-policy accounting input source
no bgp-policy accounting output source
no bgp-policy source ip-prec-map
no bgp-policy source ip-qos-map
no bgp-policy destination ip-prec-map
no bgp-policy destination ip-qos-map
interface TenGigabitEthernet1/0/1
switchport
switchport access vlan 1
switchport trunk allowed vlan 10-12,16,24-26,33,98,99
switchport private-vlan trunk encapsulation dot1q
--More--                            switchport private-vlan trunk native vlan tag
switchport mode trunk
no switchport nonegotiate
no switchport protected
no switchport block multicast
no switchport block unicast
no ip arp inspection trust
ip arp inspection limit rate 15 burst interval 1
load-interval 300
no mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
cdp tlv location
cdp tlv app
arp arpa
arp timeout 14400
hold-queue 2000 in
hold-queue 0 out
interface TenGigabitEthernet1/0/2
switchport
load-interval 300
cdp tlv location
cdp tlv app
arp arpa
arp timeout 14400
--More--                            spanning-tree cost 0
hold-queue 2000 in
hold-queue 0 out
interface TenGigabitEthernet1/0/3
switchport
load-interval 300
cdp tlv location
cdp tlv app
arp arpa
arp timeout 14400
hold-queue 2000 in
hold-queue 0 out
interface TenGigabitEthernet1/0/4
switchport
--More--                            no switchport block unicast
load-interval 300
cdp tlv location
cdp tlv app
arp arpa
arp timeout 14400
hold-queue 2000 in
hold-queue 0 out
interface TenGigabitEthernet1/0/5
switchport
load-interval 300
cdp tlv location
cdp tlv app
arp arpa
arp timeout 14400
hold-queue 2000 in
hold-queue 0 out
--More--                            no bgp-policy accounting input source
interface TenGigabitEthernet1/0/6
no switchport
ip address 192.168.150.1 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
no mab
cdp tlv location
cdp tlv app
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
--More--                            no bgp-policy destination ip-qos-map
interface Vlan1
no ip address
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
shutdown
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan10
description Academic_Staff
ip dhcp relay information trusted
ip address 192.168.88.4 255.255.255.0
ip helper-address global 192.168.8.20
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
--More--                            ip cef accounting non-recursive internal
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan11
description Non_Academic
ip address 192.168.11.4 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
--More--                            ip igmp tcn query interval 10
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan12
description Parent
ip address 192.168.12.4 255.255.252.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
--More--                             ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan16
description Student
ip address 192.168.16.4 255.255.248.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan24
description Guest
ip address 192.168.24.4 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan25
description Account_Departme
--More--                            ip address 192.168.25.4 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan26
description HR_Department
ip address 192.168.26.4 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
--More--                            ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan33
description Prototype
ip address 192.168.33.4 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
--More--                            ipv6 nd ns-interval 0
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan98
description Network_Admin
ip address 192.168.98.4 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
interface Vlan99
ip address 192.168.99.128 255.255.255.0
ip redirects
ip unreachables
ip proxy-arp
ip mtu 1500
ip route-cache cef
ip route-cache
ip split-horizon
ip igmp version 2
load-interval 300
ipv6 nd nud igp
  ipv6 redirects
  ipv6 unreachables
arp arpa
arp timeout 14400
hold-queue 75 in
hold-queue 0 out
ip default-gateway 192.168.99.1
--More--                           ip classless
ip nsf-converge 10
ip http server
ip http port 80
ip http authentication local
ip http secure-server
ip http secure-port 443
ip http secure-active-session-modules all
ip http max-connections 50
ip http timeout-policy idle 180 life 180 requests 25
ip http active-session-modules all
ip http client cache memory pool 100
ip http client cache memory file 2
ip http client cache ager interval 5
ip http client connection timeout 10
ip http client connection retry 1
ip http client connection idle timeout 30
ip http client response timeout 30
ip http path webui:/express
ip route static adjust-time 60
ip route static inter-vrf
ip prefix-list sequence-number
ip sla low-memory 368207323
logging history size 1
logging history warnings
logging trap informational
logging delimiter tcp
no logging origin-id
logging facility local7
no logging source-interface
logging server-arp
cdp run
cdp tlv location
cdp tlv app
ipv6 prefix-list sequence-number
ipv6 neighbor binding reachable-lifetime 300 stale-lifetime  86400 down-lifetime 86400
no ipv6 neighbor binding logging
snmp-server view v1default iso included
snmp-server view v1default internet included
snmp-server view v1default snmpUsmMIB excluded
snmp-server view v1default snmpVacmMIB excluded
snmp-server view v1default snmpCommunityMIB excluded
snmp-server view v1default ciscoMgmt.252 excluded
snmp-server community rafflesia@puchongv1default RO
snmp-server priority normal
no snmp-server trap link ietf
no snmp-server trap link switchover
snmp-server trap authentication vrf
snmp-server trap authentication acl-failure
snmp-server trap authentication unknown-context
snmp-server trap retry 3
snmp-server trap timeout 30
snmp-server packetsize 1500
snmp-server queue-length 10
snmp-server spi get timeout 10000
snmp-server spi set timeout 10000
snmp-server chassis-id FOC1726V0TB
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps flowmon
snmp-server enable traps transceiver all
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps rf
snmp-server enable traps memory
--More--                           snmp-server enable traps cpu threshold
snmp-server enable traps wireless bsnMobileStation bsnAccessPoint bsnAPProfile bsnAPParamUpdate bsnRogue bsn80211SecurityTrap client mobility RRM mfp AP rogue
snmp-server enable traps tty
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps flash insertion removal
snmp-server enable traps power-ethernet police
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps license
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps event-manager
snmp-server enable traps ipmulticast
snmp-server enable traps local-auth
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps ipsla
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server inform retries 3 timeout 15 pending 25
snmp mib flowmon alarmhistorysize 500
snmp mib notification-log globalsize 500
snmp mib notification-log globalageout 15
snmp mib community-map  College@puchong engineid 80000009030044ADD9038000
tacacs-server cache expiry 24 enforce hours
radius-server attribute 77 include-in-acct-req
radius-server attribute 77 include-in-access-req
radius-server attribute 11 default direction out
radius-server attribute nas-port format a
radius-server attribute 31 mac format default lower-case
radius-server cache expiry 24 enforce hours
radius-server transaction max-tries 8
radius-server retransmit 3
radius-server timeout 5
radius-server ipc-limit in 10
radius-server ipc-limit done 10
radius-server vsa send accounting
radius-server vsa send authentication
radius server College_Radius
address ipv4 192.168.8.23 auth-port 1812 acct-port 1813
timeout 500
retransmit 20
key College@puchong
--More--                           !
radius ip-input-bypass
ipv6 access-list log-update threshold 2147483647
alias exec h help
alias exec lo logout
alias exec p ping
alias exec r resume
alias exec s show
alias exec u undebug
alias exec un undebug
alias exec w where
no configuration mode exclusive
default-value exec-character-bits 7
default-value special-character-bits 7
default-value data-character-bits 8
line con 0
exec-timeout 10 0
timeout login response 30
privilege level 1
no media-type rj45 switch 1
no media-type rj45 switch 2
no media-type rj45 switch 3
no media-type rj45 switch 4
no media-type rj45 switch 5
no media-type rj45 switch 6
no media-type rj45 switch 7
no media-type rj45 switch 8
no media-type rj45 switch 9
modem answer-timeout 15
modem dtr-delay 5
length 24
width 80
history size 20
monitor
escape-character soft DEFAULT
escape-character DEFAULT
databits 8
stopbits 1
start-character 17
stop-character 19
speed 9600
line aux 0
exec-timeout 10 0
privilege level 1
modem dtr-delay 5
length 24
width 80
--More--                            history size 20
monitor
databits 8
stopbits 1
start-character 17
stop-character 19
speed 9600
line vty 0 4
exec-timeout 10 0
privilege level 1
password Cisco123
modem dtr-delay 5
length 24
width 80
history size 20
monitor
start-character 17
stop-character 19
line vty 5 15
exec-timeout 10 0
privilege level 1
password Cisco123
modem dtr-delay 5
length 24
width 80
history size 20
monitor
start-character 17
stop-character 19
monitor event-trace stacktrace
monitor event-trace timestamps datetime msec
scheduler max-task-time 2000
scheduler process-watchdog normal
ntp maxdistance 8
ntp broadcastdelay 0
cns id hostname
cns id hostname event
cns id hostname image
cns image retry 60
wsma id hostname
--More--                           wsma agent exec
profile httplistener
profile httpslistener
profile webui_service
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
encap soap11
wsse
transport http path /wsma
max-message 50
no keepalive
wsma profile listener httpslistener
encap soap11
wsse
transport https path /wsma
max-message 50
no keepalive
wsma profile listener webui_service
encap soap11
wsse
transport http path /webui
max-message 50
no keepalive
mac address-table notification change interval 1
mac address-table notification change history-size 1
netconf max-sessions 4
netconf lock-time 10
netconf max-message 0
event manager scheduler script thread class default number 1
event manager scheduler applet thread class default number 32
event manager scheduler call-home thread class default number 32
event manager scheduler shell thread class default number 1
event manager scheduler shell thread class Z number 1
event manager history size events 10
event manager history size traps 10
event manager detector rpc max-sessions 4
event manager detector routing bootup-delay 0
wireless mobility group keepalive count 3
wireless mobility group keepalive interval 10
wireless mobility group name default
wireless mobility oracle ip 0.0.0.0
wireless mobility dscp 0
--More--                           wireless mobility multicast ip 0.0.0.0
wireless management interface Vlan99
wireless wps rogue ap rldp retries 1
wireless wps rogue ap timeout 1200
wireless wps rogue auto-contain level 1
wireless wps rogue detection report-interval 10
wireless wps ap-authentication threshold 1
wireless linktest frame-size 500
wireless linktest number-of-frames 20
wireless load-balancing denial 3
wireless load-balancing window 5
wireless client band-select client-rssi -80
wireless client band-select cycle-count 2
wireless client band-select cycle-threshold 200
wireless client band-select expire dual-band 60
wireless client band-select expire suppression 20
wireless client fast-ssid-change
wireless client max-user-login 0
wireless client timers auth-timeout 10
wireless client user-timeout 300
wireless peer-blocking forward-upstream
wireless probe limit 2 500
wireless rf-network default
wireless security dot1x eapol-key retries 2
wireless security dot1x eapol-key timeout 1000
wireless security dot1x group-key interval 3600
wireless security dot1x identity-request retries 2
wireless security dot1x identity-request timeout 30
wireless security dot1x radius call-station-id ipaddress
wireless security dot1x request retries 2
wireless security dot1x request timeout 30
wireless security dot1x wep key index 0
wireless wgb client-macfilter
wireless media-stream message Email
wireless media-stream message Notes
wireless media-stream message URL
wireless media-stream message phone
wireless multicast
wireless mgmt-via-wireless
wlan College_Dot1x 99 College
aaa-override
accounting-list
channel-scan defer-time 100
client association limit 200
client vlan College-Group
dtim dot11 24ghz 1
dtim dot11 5ghz 1
exclusionlist timeout 60
ip access-group web none
ip access-group none
ip dhcp server 0.0.0.0
ipv6 traffic-filter web none
ipv6 traffic-filter none
mac-filtering
radio all
security wpa wpa1
security wpa wpa1 ciphers aes
--More--                            security dot1x authentication-list Dot1x_Authentication
security dot1x encryption 104
security static-wep-key authentication open
security tkip hold-down 60
security web-auth authentication-list
security web-auth parameter-map
service-policy client input unknown
service-policy client output unknown
service-policy input unknown
service-policy output unknown
session-timeout 1800
no shutdown
wlan Guest_vap 24 College_Guest
accounting-list
client association limit 0
client vlan Guest
dtim dot11 24ghz 1
dtim dot11 5ghz 1
mac-filtering
radio all
no security wpa akm dot1x
security wpa akm psk set-key ascii 0 0123456789
no shutdown
wlan Guest-Test 124 Guest-Test
aaa-override
accounting-list
client vlan Guest
dtim dot11 24ghz 1
dtim dot11 5ghz 1
mac-filtering
radio all
--More--                            no security wpa
no security wpa wpa2
no security wpa wpa2 ciphers aes
security web-auth
security web-auth authentication-list local_webauth
security web-auth parameter-map College_Guest_Web
no shutdown
ap capwap multicast service-policy output unknown
ap capwap retransmit count 3
ap capwap retransmit interval 2
ap capwap timers primary-discovery-timeout 30
ap capwap timers primed-join-timeout 0
ap capwap backup primary C5760-WC01 192.168.99.128
ap capwap backup secondary C5760-WC02 192.168.99.129
ap capwap master
ap dot1x username  password clear
ap ethernet duplex auto speed auto
ap led
ap mgmtuser username admin password 0 Cisco123 secret 0 P@ssword
ap reporting-period 120
ap static-ip domain default
ap static-ip name-server 0.0.0.0
ap syslog host 255.255.255.255
ap syslog level information
ap tftp-downgrade 0.0.0.0 default
no ap auth-list ap-policy authorize-ap
no ap auth-list ap-policy authorize-lsc-ap
ap auth-list ap-policy mic
no ap auth-list ap-policy ssc
ap capwap timers discovery-timeout 5
ap capwap timers heartbeat-timeout 10
no ap dot11 24ghz edca-parameters custom-voice
no ap dot11 24ghz edca-parameters optimized-video-voice
no ap dot11 24ghz edca-parameters optimized-voice
no ap dot11 24ghz edca-parameters svp-voice
no ap dot11 24ghz edca-parameters wmm-default
no ap dot11 5ghz edca-parameters custom-voice
no ap dot11 5ghz edca-parameters optimized-video-voice
no ap dot11 5ghz edca-parameters optimized-voice
no ap dot11 5ghz edca-parameters svp-voice
no ap dot11 5ghz edca-parameters wmm-default
ap country MY
ap dot1x max-sessions 0
ap dot11 24ghz rrm group-mode auto
ap dot11 24ghz rrm channel dca anchor-time 0
--More--                           ap dot11 24ghz rrm channel dca global auto
no ap dot11 24ghz rrm channel dca global once
ap dot11 24ghz rrm channel dca interval 0
ap dot11 24ghz rrm channel dca min-metric -95
ap dot11 24ghz rrm channel dca sensitivity medium
ap dot11 24ghz rrm channel dca 1
ap dot11 24ghz rrm channel dca 6
ap dot11 24ghz rrm channel dca 11
ap dot11 24ghz rrm channel foreign
no ap dot11 24ghz rrm channel load
ap dot11 24ghz rrm channel noise
ap dot11 24ghz rrm coverage
ap dot11 24ghz rrm coverage data fail-percentage 50
ap dot11 24ghz rrm coverage data packet-count 50
ap dot11 24ghz rrm coverage data rssi-threshold -80
ap dot11 24ghz rrm coverage exception global 25
ap dot11 24ghz rrm coverage level global 3
ap dot11 24ghz rrm coverage voice fail-percentage 50
ap dot11 24ghz rrm coverage voice packet-count 100
ap dot11 24ghz rrm coverage voice rssi-threshold -80
no ap dot11 24ghz rrm logging channel
no ap dot11 24ghz rrm logging coverage
no ap dot11 24ghz rrm logging foreign
no ap dot11 24ghz rrm logging load
no ap dot11 24ghz rrm logging noise
no ap dot11 24ghz rrm logging performance
no ap dot11 24ghz rrm logging txpower
ap dot11 24ghz rrm monitor
ap dot11 24ghz rrm monitor channel-list country
ap dot11 24ghz rrm monitor coverage 180
ap dot11 24ghz rrm monitor load 60
ap dot11 24ghz rrm monitor noise 180
ap dot11 24ghz rrm monitor signal 60
ap dot11 24ghz rrm ndp-type transparent
ap dot11 24ghz rrm profile clients 12
ap dot11 24ghz rrm profile foreign 10
ap dot11 24ghz rrm profile noise -70
ap dot11 24ghz rrm profile throughput 1000000
ap dot11 24ghz rrm profile utilization 80
ap dot11 24ghz rrm txpower auto
ap dot11 24ghz rrm txpower max 30
ap dot11 24ghz rrm txpower min -10
ap dot11 24ghz rrm channel cleanair-event sensitivity low
ap dot11 24ghz cleanair
ap dot11 24ghz cleanair alarm air-quality
ap dot11 24ghz cleanair alarm air-quality threshold 10
ap dot11 24ghz cleanair alarm device
no ap dot11 24ghz cleanair alarm device bt-discovery
no ap dot11 24ghz cleanair alarm device bt-link
no ap dot11 24ghz cleanair alarm device canopy
no ap dot11 24ghz cleanair alarm device cont-tx
no ap dot11 24ghz cleanair alarm device dect-like
no ap dot11 24ghz cleanair alarm device fh
ap dot11 24ghz cleanair alarm device inv
no ap dot11 24ghz cleanair alarm device jammer
no ap dot11 24ghz cleanair alarm device mw-oven
ap dot11 24ghz cleanair alarm device nonstd
--More--                           no ap dot11 24ghz cleanair alarm device superag
no ap dot11 24ghz cleanair alarm device tdd-tx
no ap dot11 24ghz cleanair alarm device video
no ap dot11 24ghz cleanair alarm device wimax-fixed
no ap dot11 24ghz cleanair alarm device wimax-mobile
no ap dot11 24ghz cleanair alarm device xbox
no ap dot11 24ghz cleanair alarm device zigbee
ap dot11 24ghz cleanair device bt-discovery
ap dot11 24ghz cleanair device bt-link
ap dot11 24ghz cleanair device canopy
ap dot11 24ghz cleanair device cont-tx
ap dot11 24ghz cleanair device dect-like
ap dot11 24ghz cleanair device fh
ap dot11 24ghz cleanair device inv
ap dot11 24ghz cleanair device jammer
ap dot11 24ghz cleanair device mw-oven
ap dot11 24ghz cleanair device nonstd
ap dot11 24ghz cleanair device report
ap dot11 24ghz cleanair device superag
ap dot11 24ghz cleanair device tdd-tx
ap dot11 24ghz cleanair device video
ap dot11 24ghz cleanair device wimax-fixed
ap dot11 24ghz cleanair device wimax-mobile
ap dot11 24ghz cleanair device xbox
ap dot11 24ghz cleanair device zigbee
ap dot11 24ghz rrm tpc-threshold -70
ap dot11 24ghz rrm txpower 1
ap dot11 24ghz beaconperiod 100
ap dot11 24ghz cac media-stream multicast-direct max-retry-percent 80
ap dot11 24ghz cac media-stream multicast-direct min-client-rate six
ap dot11 24ghz cac multimedia max-bandwidth 85
ap dot11 24ghz media-stream multicast-direct client-maximum 0
ap dot11 24ghz media-stream multicast-direct radio-maximum 0
ap dot11 24ghz cac video max-bandwidth 0
ap dot11 24ghz cac video roam-bandwidth 0
ap dot11 24ghz cac voice max-bandwidth 75
ap dot11 24ghz cac voice load-based
ap dot11 24ghz cac voice roam-bandwidth 6
ap dot11 24ghz cac voice sip bandwidth 64 sample-interval 20
ap dot11 24ghz cac voice stream-size 84000 max-streams 2
ap dot11 24ghz cac voice tspec-inactivity-timeout ignore
ap dot11 24ghz dot11g
ap dot11 24ghz dot11n a-mpdu tx priority 0
ap dot11 24ghz dot11n a-mpdu tx priority 4
ap dot11 24ghz dot11n a-mpdu tx priority 5
ap dot11 24ghz dot11n a-msdu tx priority 0
ap dot11 24ghz dot11n a-msdu tx priority 1
ap dot11 24ghz dot11n a-msdu tx priority 2
ap dot11 24ghz dot11n a-msdu tx priority 3
ap dot11 24ghz dot11n a-msdu tx priority 4
ap dot11 24ghz dot11n a-msdu tx priority 5
ap dot11 24ghz dot11n guard-interval any
no ap dot11 24ghz dot11n guard-interval long
ap dot11 24ghz dot11n rifs rx
no ap dot11 24ghz exp-bwreq
ap dot11 24ghz fragmentation 2346
ap dot11 24ghz preamble short
--More--                           ap dot11 24ghz rate RATE_1M mandatory
ap dot11 24ghz rate RATE_2M mandatory
ap dot11 24ghz rate RATE_5_5M mandatory
ap dot11 24ghz rate RATE_6M supported
ap dot11 24ghz rate RATE_9M supported
ap dot11 24ghz rate RATE_11M mandatory
ap dot11 24ghz rate RATE_12M supported
ap dot11 24ghz rate RATE_18M supported
ap dot11 24ghz rate RATE_24M supported
ap dot11 24ghz rate RATE_36M supported
ap dot11 24ghz rate RATE_48M supported
ap dot11 24ghz rate RATE_54M supported
no ap dot11 24ghz shutdown
no ap dot11 24ghz tsm
ap dot11 24ghz world-mode
ap dot11 5ghz rrm group-mode auto
no ap dot11 5ghz rrm ccx location-measurement
ap dot11 5ghz rrm channel dca anchor-time 0
ap dot11 5ghz rrm channel dca chan-width-11n 20
ap dot11 5ghz rrm channel dca global auto
no ap dot11 5ghz rrm channel dca global once
ap dot11 5ghz rrm channel dca interval 0
ap dot11 5ghz rrm channel dca min-metric -95
ap dot11 5ghz rrm channel dca sensitivity medium
ap dot11 5ghz rrm channel dca 36
ap dot11 5ghz rrm channel dca 40
ap dot11 5ghz rrm channel dca 44
ap dot11 5ghz rrm channel dca 48
ap dot11 5ghz rrm channel dca 52
ap dot11 5ghz rrm channel dca 56
ap dot11 5ghz rrm channel dca 60
ap dot11 5ghz rrm channel dca 64
ap dot11 5ghz rrm channel dca 149
ap dot11 5ghz rrm channel dca 153
ap dot11 5ghz rrm channel dca 157
ap dot11 5ghz rrm channel dca 161
ap dot11 5ghz rrm channel foreign
no ap dot11 5ghz rrm channel load
ap dot11 5ghz rrm channel noise
ap dot11 5ghz rrm coverage
ap dot11 5ghz rrm coverage data fail-percentage 50
ap dot11 5ghz rrm coverage data packet-count 50
ap dot11 5ghz rrm coverage data rssi-threshold -80
ap dot11 5ghz rrm coverage exception global 25
ap dot11 5ghz rrm coverage level global 3
ap dot11 5ghz rrm coverage voice fail-percentage 50
ap dot11 5ghz rrm coverage voice packet-count 100
ap dot11 5ghz rrm coverage voice rssi-threshold -80
no ap dot11 5ghz rrm logging channel
no ap dot11 5ghz rrm logging foreign
no ap dot11 5ghz rrm logging load
no ap dot11 5ghz rrm logging performance
no ap dot11 5ghz rrm logging txpower
ap dot11 5ghz rrm monitor
ap dot11 5ghz rrm monitor channel-list country
ap dot11 5ghz rrm monitor coverage 180
ap dot11 5ghz rrm monitor load 60
--More--                           ap dot11 5ghz rrm monitor noise 180
ap dot11 5ghz rrm monitor signal 60
ap dot11 5ghz rrm ndp-type transparent
ap dot11 5ghz rrm profile clients 12
ap dot11 5ghz rrm profile foreign 10
ap dot11 5ghz rrm profile noise -70
ap dot11 5ghz rrm profile throughput 1000000
ap dot11 5ghz rrm profile utilization 80
ap dot11 5ghz rrm txpower auto
ap dot11 5ghz rrm txpower max 30
ap dot11 5ghz rrm txpower min -10
ap dot11 5ghz rrm channel cleanair-event sensitivity low
ap dot11 5ghz cleanair
ap dot11 5ghz cleanair alarm air-quality
ap dot11 5ghz cleanair alarm air-quality threshold 10
ap dot11 5ghz cleanair alarm device
no ap dot11 5ghz cleanair alarm device canopy
no ap dot11 5ghz cleanair alarm device cont-tx
no ap dot11 5ghz cleanair alarm device dect-like
ap dot11 5ghz cleanair alarm device inv
no ap dot11 5ghz cleanair alarm device jammer
ap dot11 5ghz cleanair alarm device nonstd
no ap dot11 5ghz cleanair alarm device radar
no ap dot11 5ghz cleanair alarm device superag
no ap dot11 5ghz cleanair alarm device tdd-tx
no ap dot11 5ghz cleanair alarm device video
no ap dot11 5ghz cleanair alarm device wimax-fixed
no ap dot11 5ghz cleanair alarm device wimax-mobile
ap dot11 5ghz cleanair device canopy
ap dot11 5ghz cleanair device cont-tx
ap dot11 5ghz cleanair device dect-like
ap dot11 5ghz cleanair device inv
ap dot11 5ghz cleanair device jammer
ap dot11 5ghz cleanair device nonstd
ap dot11 5ghz cleanair device radar
ap dot11 5ghz cleanair device report
ap dot11 5ghz cleanair device superag
ap dot11 5ghz cleanair device tdd-tx
ap dot11 5ghz cleanair device video
ap dot11 5ghz cleanair device wimax-fixed
ap dot11 5ghz cleanair device wimax-mobile
ap dot11 5ghz rrm tpc-threshold -70
ap dot11 5ghz rrm txpower 1
ap dot11 5ghz beaconperiod 100
ap dot11 5ghz cac media-stream multicast-direct max-retry-percent 80
ap dot11 5ghz cac media-stream multicast-direct min-client-rate six
ap dot11 5ghz cac multimedia max-bandwidth 85
ap dot11 5ghz media-stream multicast-direct client-maximum 0
ap dot11 5ghz media-stream multicast-direct radio-maximum 0
ap dot11 5ghz cac video load-based
ap dot11 5ghz cac video max-bandwidth 0
ap dot11 5ghz cac video roam-bandwidth 0
ap dot11 5ghz cac voice max-bandwidth 75
ap dot11 5ghz cac voice load-based
ap dot11 5ghz cac voice roam-bandwidth 6
ap dot11 5ghz cac voice sip bandwidth 64 sample-interval 20
ap dot11 5ghz cac voice stream-size 84000 max-streams 2
--More--                           ap dot11 5ghz cac voice tspec-inactivity-timeout ignore
ap dot11 5ghz dot11n
ap dot11 5ghz dot11n a-mpdu tx priority 0
ap dot11 5ghz dot11n a-mpdu tx priority 4
ap dot11 5ghz dot11n a-mpdu tx priority 5
ap dot11 5ghz dot11n a-msdu tx priority 0
ap dot11 5ghz dot11n a-msdu tx priority 1
ap dot11 5ghz dot11n a-msdu tx priority 2
ap dot11 5ghz dot11n a-msdu tx priority 3
ap dot11 5ghz dot11n a-msdu tx priority 4
ap dot11 5ghz dot11n a-msdu tx priority 5
ap dot11 5ghz dot11n guard-interval any
no ap dot11 5ghz dot11n guard-interval long
ap dot11 5ghz dot11n rifs rx
no ap dot11 5ghz exp-bwreq
ap dot11 5ghz fragmentation 2346
ap dot11 5ghz rate RATE_6M mandatory
ap dot11 5ghz rate RATE_9M supported
ap dot11 5ghz rate RATE_12M mandatory
ap dot11 5ghz rate RATE_18M supported
ap dot11 5ghz rate RATE_24M mandatory
ap dot11 5ghz rate RATE_36M supported
ap dot11 5ghz rate RATE_48M supported
ap dot11 5ghz rate RATE_54M supported
no ap dot11 5ghz shutdown
no ap dot11 5ghz tsm
ap dot11 5ghz world-mode
no ap dot11 5ghz channelswitch mode 0
ap dot11 5ghz power-constraint 0
ap group default-group
description
ap group College_WiFi_Group
description
wlan Guest_vap
  vlan Guest
wlan College_Dot1x
  vlan
wlan Guest-Test
  vlan Guest
wlan Guest_try
  vlan Guest
end
can you remove the custom page command from the global parameter map
also where did you get the customer webpages from?
what clients have you tested so far?
1905
