I created a wlan on my Cisco 8510 controller for guest users and I would just like for them to get acceptable use terms and then click accept or reject. The users get the default page when it is selected. I uploaded the login.tar from the webauth bundle from Cisco just to see if that works figuring I would just modify it once I verified I could see it when connecting to the WLAN.
When I connect to the WLAN with no layer 2 security and layer 3 only setup for Passthrough I am not getting any page with "Web Login Page" set to "Customized". If I change it back to "Internal", I get the default Cisco page.
I turned off WebAuth SecureWeb so that I would not have to load a certificate on the controller and the wireless users will not get prompted about a certificate error.
When I go to the http://1.1.1.1/fs/customwebauth/login.html link I am seeing the custom page but I cannot see it when I just try to browse to the internet nor am I getting any web pages. Web access works fine with the Internal page.
I did reboot the controller just in case also. The controller is running 7.6.130 code.
Thank you for any help.
