CWA page does not redirect
Hi there,
I am having strange issue.
I have configured a wlan with Mac Filtering that is pointing to ISE. Followed this guide https://supportforums.cisco.com/docs/DOC-26442
Now, when user tries to connect to the wlan, it gets stuck in DHCP_REQD state. On troubleshooting I found that the ISE authenticates with Wireless MAB policy and points to the authorization profile where CWA redirect is configured. The WLC receives the redirect acl with redirect url but does not apply it on the client.
On ISE:
On WLC:
the ACL "tempcwa" allows traffic to and from ISE, DNS, DHCP, but I am not able to get IP. Even when I try manual IP address, I am not able to ping ISE. I am sure ACL is all ok! My DHCP works perfect for other WLANs with WLC webauth settings in the same subnet as CWA.
I am using AIR-CT5760, 03.02.02.SE, ct5760-ipservicesk9 and ISE 1.2 VM
Please help me!!
Everyone's tags (5)
1 ACCEPTED SOLUTION
Re: CWA page does not redirect
If the device is not able to get dhcp the. It can't use the redirect page.
I would remove the ACL and see if it allows the client to get an address.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Steve
Thanks for your response..
If I remove the ACL then how the traffic destined to ISE will be allowed? The interesting part is, I am getting hits on the redirect ACL but client can not receive IP address.
DHCP is working fine and if I assign manual IP then DHCP is not the matter.
If Redirect ACL and ISE page is forwarded to WLC from ISE then why this is not working for clients??
Moreover, I noticed that even DACL is not being pushed to wireless clients from other authorization profiles. The traffic gets Permit_access but DACL does not restrict..
I think these two issues are interlinked..
Please suggest..
Any suggestion???
Hall of Fame Super Silver
Like Steve mentioned, you need to fix the dhcp first. If you remove the preauth acl and then just use the WLC internal webauth, does it work? If so, then you need to look at your preauth acl.
-Scott
I have checked by manually assigning the IP address. Still no luck..
I finally got it working, my ACL was wrong.
The redirect ACL should look like as follows:
Deny UDP any any
Deny ip any host
Deny ip host any
Permit TCP any any HTTTP
Permit TCP any any HTTTPS
After changing the ACL, CWA redirect page started to show up!!
Thanks to Stephen.
753
