default gateway dhcp server problems with 7.4.110.0
baumgartnerm
Hi together,
I upgraded today my WLC (ISM-SRE-300-K9) from 7.0.220.0 to the current version 7.4.110.0.
All clients are connected, but the default gateway is incorrectly set.
For example my default gateway is 192.168.0.254 (set in the admin-interface)
I get on the client the default gateway: 254.0.168.192
I have already tried to set it incorrect in the admin interface, but the interface says, that this is not allowed.
Any ideas, what I have to do?
Thanks!
Manu
12 Replies 12
ericgarnel
Level 7
Level 7
check & see what the DHCP server is handing out.
Also, check under WLAN | Advanced tab to see if you are overriding the DHCP settings of the interface
Eric
Hi Eric,
there is no overriding DHCP server.
The DHCP server is correctly configured and handing out all correct except the gateway...
I've already tried to delete the scope and add a new scope.
Manu
post "show interface detail " output to see what's wrong with it
Rasika
the gateway ip: 254.0.168.192 was an example.
the gateway ip I get with this configure is: 33.36.168.192
(Cisco Controller) show>interface detailed vlan107
Interface Name................................... vlan107
MAC Address...................................... c8:9c:1d:6a:81:80
IP Address....................................... 192.168.36.10
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.36.33
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 107
Quarantine-vlan.................................. 0
NAS-Identifier................................... SR-WLC-1
Physical Port.................................... 1
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 192.168.250.12
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Hi Manuel,
Little confused here :-(
You mean to say that your interface has the default gateway configured as 192.168.36.33 but your DHCP client is getting the default gateway ip address as 33.36.168.192???
What  DHCP server are you using?
Najaf
Hi Najaf,
yes, this is right.
I am using the internal DHCP server of the WLC.
Some further details:
I upgraded from 7.0.240.0 to the current version.
The WLC is a ISM-SRE-300-K9 in a Cisco 1941/K9 and 9 Cisco AIR-LAP1042N-A-K9 Access Points.
Manuel
Could you please share the output of below command?
show dhcp detailed
Also try deleting this scope and try configuring a new scope with different name and same parameters
Najaf
Hi Najaf,
I have already tried to configure a new scope with a different name and same parameters -> same problem.
Here your output:
(Cisco Controller) >show dhcp detailed Mitarbeiter
Scope: Mitarbeiter
Enabled.......................................... Yes
Lease Time....................................... 86400 (1 day )
Pool Start....................................... 192.168.36.100
Pool End......................................... 192.168.36.199
Network.......................................... 192.168.36.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 192.168.36.33  0.0.0.0  0.0.0.0
DNS Domain....................................... wlan.vn.idowa.de
DNS.............................................. 192.168.1.221  192.168.1.207  0.0.0.0
Netbios Name Servers............................. 0.0.0.0  0.0.0.0  0.0.0.0
Manuel
kcnajaf
Level 7
Level 7
That is interesting.
On DHCP scope can you try setting gateway as 33.36.168.192 and verify if clients are getting default gateway as 192.168.36.33 :-)
Najaf
I have already tried this...
It's not allowed to set an incorrect gateway...
Manuel
Rob Huffman
Hi Manu,
Have a look at this 7.4 bug
CSCuh20357
Related Bug Information
7.4 SRE-WLC DHCP Server, default gateway and dns offer reversed
Symptom: An SRE WLC configured as a DHCP Server may offer octet reversed default  gateway and DNS server values (eg 4.3.2.1 instead of 1.2.3.4) Conditions: SRE-WLC running 7.4.100.0 or 7.4.100.60 Workaround: Use an external DHCP server or downgrade to pre 7.4 code. More Info:
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Hi Rob,
thanks for the bug description.
Hopefully it will be fixed in future releases...
Manu
