Bronze
Default SSID Disappears When Additional SSID Added
I have an issue when configuring an additional SSID for an autonomous AP, hopefully someone can point me in the right direction.
Currently there is one SSID configured to use VLAN 1, Bridge Group 1, and the normal dot11Radio0 and FastEthernet0 interfaces. I can associate clients to this SSID without issue.
I then configure a second SSID, and assign it to VLAN 253, Bridge Group 253, and sub-interfaces dot11Radio0.253 and FastEthernet0.253. Clients can associtae with this SSID ok, but now clients are unable to associate with the original SSID on vlan 1.
Is there something key that I would have missed or any particular debug commands to run that will narrow down the problem?
APs are Aironet 1230B's running c1200-k9w7-mx.123-7.JA1.
Paul
HTH Paul ****Please rate useful posts****
Everyone's tags (4)
Bronze
Re: Default SSID Disappears When Additional SSID Added
Sorted this.
I needed to specify vlan 1 with the encryption methods and ssid, eg:
dot11 ssid wlan1
vlan 1
authentication open eap eap_methods
authentication network-eap eap_methods
int dot11Radio0
encryption vlan 1 key 1 size 128bit 7 1234567890ABCDEF1234567890 transmit-key
encryption vlan 1 mode wep mandatory
Paul
Are you using MBSSID command? This is the commadn that is needed to broadcast multiple SSIDs.
If not using it, issue the command under the ssid and the radio interfaces.
under the ssid:
mbssid guest-mode.
under the radio:
mbssid.
you may also give a look to this discussion:
https://supportforums.cisco.com/thread/2063707
Amjad
Rating useful replies is more useful than saying "Thank you"
541
