Design with WiSM
I plan to have our access points physically connected to the access switches which, in turn, connect to the Distro switches. Where should I install my WiSM modules? Distro or Core? I think it should be at the Core since "all wireless data traffic is tunneled through the controller". Any suggestions? Any Cisco documentations on this?
-B
1 REPLY
Hall of Fame Super Silver
Re: Design with WiSM
Here is a good link. It depends if you are running layer 3 to the access, layer 3 just between the distro and the cores switches or just running layer 2 all around.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/emob41dg/ch2_Arch.html#wp1032226
-Scott
141
