#DHCP-3-DHCP_PKT_LOOPED - possible network loop!
Hi guys,
I think I am not the only one person who was able to see this message on vWLC Logs-> Message logs page:
*DHCP Socket Task: Jul 11 17:31:45.644: #DHCP-3-DHCP_PKT_LOOPED: dhcp_proxy.c:3768 Received a DHCP packet sent by the controller itself possible network loop!
Does anyone knows, why it happens?
I'm seeing this aswell. Anyone have any ideas?
vWLC v7.5.102.0
VIP Purple
Have you configured an external DHCP server for the dynamic interfaces ? vWLC does not support internal DHCP
Try disabling dhcp proxy (using config dhcp proxy disable ) & see if that helps
Rasika
**** Pls rate all useful responses ****
Yes, the dynamic interfaces have a external DHCP configured.
I'll try disabling the proxy and see if the erorrs still appear.
Thanks Rasika! And thank you for writing a great blog
Still appearing in the logs unfortunatley... any other ideas?
VIP Purple
Hi Evan,
Did you try restarting the VM/vWLC & see if that helps.
I have a vWLC on my test environment running on 7.6.100.0 & I could not see this sort of logs. by the way my vWLC is having very low usage & cannot compare with production vWLC like yours.
Do you see this when client associating or it comes every regular interval whether clients are there or not ?
Rasika
Hi Rasika,
I'll see if I can schedule a reboot of the WLC in the coming days.
The appearance of this in the logs is regular, even without new client associataions.
Deployment is 30 APs with about 120 clients.
Evan.
VIP Purple
Re: #DHCP-3-DHCP_PKT_LOOPED - possible network loop!
Hi Evan,
I would advise you to open a TAC case if you get TAC support (I feel it may be a bug, who knows).
So you can incorporate any service distruptive troubleshooting required with them if you get organise a maintenance window
NB: You can revert the proxy settings back (since it did not helped) as it will help to hide your original DHCP address when clients get DHCP info.
Rasika
Have opened a TAC case
I'll see if I'm able to upgrade to 7.6 soon, I just need to schedule a maintenace window with the customer.
It turns out we are hitting a bug.. CSCuj14843
I'll be applying the fix soon and will report back.
684
