DHCP problem on AP with H-REAP enabled
Scenario: I have several APs connected in remote offices, switch ports, connecting to APs, are setup as trunk, and only allowed two wireless VLANs, and AP MGT IPs Vlan.  H-REAP is setup, Vlan Support and VLAN Mappings are all setup.  I can see MAC of users using different SSID are put into different VLAN correctly.
The Problem is: when user connected on a SSID, although the user wifi card's MAC was put into correct VLAN, DHCP requests were set duplexly to all three allowed VLANs through the switch trunk port conneting to the AP.  As a reslult, user randomly got an IP from one of three different DHCP scopes that setup for thress different purposes, two wireless SSIDs and AP MGT IPs.  The DHCP server got thress requests from three different VLANs, first come first serve...
Any way I can stop the duplexed DHCP requests sending through all allowed VLANs from APs?  Experts?  Cisco Supermen..?
P.S. my APs are LAP1142N.
Thanks a lot.
Everyone's tags (4)
Hall of Fame Super Silver
Re: DHCP problem on AP with H-REAP enabled
Well you have a good one here. So let me ask... Does this happen everywhere or can you segment it to a particular AP or even switch?
Can you capture some of the packets from the access point also and maybe just post your interface config just for kicks)
-Scott
it happend on all our recently deployed 1142s, on different switchs.  Don't think it switch realted, because on the same switch, PC users from different VLANs can get IP address no drama.
switch port config is simple
description AP
switchport trunk allowed vlan 1,3,4
switchport mode trunk description AP
vlan 1 is AP MGT, vlan 3 and 4 are for two different SSIDs.
P.S. 'VLAN Transparent' under Mesh settings on the Controller is NOT enabled.
Thanks a lot.
VLAN transparent config for Mesh doesn't affect HREAP.
On wireless client run wireshark selecting the wireless adapter on non-promiscuous mode and check the captures.
please share svi of AP connected switch
Can you post your show run-config on the wlc.
-Scott
Experts below is the radio and interface config on one of our APs.  Can you spot anything?
interface Dot11Radio0
no ip route-cache
interface Dot11Radio0.1
encapsulation dot1Q 1
no ip route-cache
bridge-group 5
bridge-group 5 subscriber-loop-control
bridge-group 5 block-unknown-source
no bridge-group 5 source-learning
no bridge-group 5 unicast-flooding
bridge-group 5 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio0.17
encapsulation dot1Q 17 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip route-cache
interface Dot11Radio1.1
no ip route-cache
bridge-group 5
interface Dot11Radio1.2
no ip route-cache
bridge-group 4
interface Dot11Radio1.17
no ip route-cache
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
encapsulation dot1Q 1 native
ip address dhcp client-id GigabitEthernet0
no ip route-cache
bridge-group 1
interface GigabitEthernet0.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
interface GigabitEthernet0.5
encapsulation dot1Q 5
no ip route-cache
bridge-group 5
671
