Community Member
DHCP reservation not working for Aironet AP (Stand Alone)
I am trying to add a reservation to my IP Pool on a 3750 switch.  From what I can tell I have the setup correctly with the client ID but for some reason it get an IP from the DATA  pool and not the WIFI pool.
Here is my config:
no ip dhcp use vrf connected
ip dhcp excluded-address 10.5.44.1 10.5.44.30
ip dhcp pool DATA
network 10.5.44.0 255.255.252.0
default-router 10.5.44.1
domain-name mydomain.com
dns-server 10.1.1.7 10.1.1.8
ip dhcp pool WIFI
host 10.5.44.100 255.255.252.0
client-identification 0100.21a0.d626.82
Basically I turned on DHCP logging and it gives the following:
*Mar  1 00:09:31: DHCPD: checking for expired leases.
*Mar  1 00:10:23: DHCPD: Sending notification of DISCOVER:
*Mar  1 00:10:23:   DHCPD: htype 1 chaddr 0021.a0d6.2882
*Mar  1 00:10:23:   DHCPD: interface = Vlan1
*Mar  1 00:10:23:   DHCPD: class id 436973636f204150206331313330
*Mar  1 00:10:23:   DHCPD: out_vlan_id 0
*Feb 28 19:10:24 EST: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 10.5.44.31.
*Mar  1 00:10:26: DHCPD: Adding binding to radix tree (10.5.44.32)
*Mar  1 00:10:26: DHCPD: Adding binding to hash tree
*Mar  1 00:10:26: DHCPD: assigned IP address 10.5.44.32 to client 0100.21a0.d628.82. (2069 0)
*Mar  1 00:10:26: DHCPD: DHCPOFFER notify setup address 10.5.44.32 mask 255.255.252.0
*Mar  1 00:10:26: DHCPD: Sending notification of ASSIGNMENT:
*Mar  1 00:10:26:  DHCPD: address 10.5.44.32 mask 255.255.252.0
*Mar  1 00:10:26:   DHCPD: htype 1 chaddr 0021.a0d6.2882
*Mar  1 00:10:26:   DHCPD: lease time remaining (secs) = 86400
*Mar  1 00:10:26:   DHCPD: interface = Vlan1
*Mar  1 00:10:26:   DHCPD: out_vlan_id 0
When I show the binding I get this:
San_Diego_SW1#sh ip d b
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
10.5.44.33          0100.21a0.d628.82       Mar 01 1993 07:10 PM    Automatic
10.5.44.100         0100.21a0.d626.82       Infinite                Manual
What in the world am I doing wrong here so that the reservation does not get used?
Thanks in advance,
--Dan
You should transfer this
You should transfer this thread to the wireless community of the forum, where it'll attract more experts from wireless domain. Wireless community is available here:
https://supportforums.cisco.com/community/5956/getting-started-wireless
A few things :
Mac address differs from client id and what is there in log.
Client ID # 0021.a0d6.2682
In Logs   # 0021.a0d6.2882
You logs seems old for feb/mar. You should enable debug ip dhcp server packets to see more details.
As per your config you have client-id and ip dhcp pool same mac address you want with you required IP, where is the problem?
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Community Member
Thanks for the reply, I have
Thanks for the reply, I have moved it to the correct area.
The problem I have is that the WAP is getting the 10.5.44.33 address and not the 10.5.44.100 address IO needed it to get.
I am missing something here just can't put my finger on it.
--Dan
VIP Purple
Hi,1.Try this:Preassigning IP
Try this:
Preassigning IP Addresses and Associating Them to a Client
address 10.5.44.100 client-id 0100.21a0.d626.82
Dont forget to rate helpful posts
Community Member
Tried it, did not work.
Tried it, did not work.  However for testing I created a reservation for a lightweight AP (AIR-LAP1131AG) and that one worked like a champ using the reservation below and picked up the 102 address.
ip dhcp pool WIFI
   host 10.5.44.102 255.255.252.0
   client-identifier 0100.260b.6332.8c
Same thing I do for the stand alone (AIR-AP1131AG) does not work.  Is there something special for the stand alone?
--Dan
224
