01-28-2011 12:28 PM - edited 07-03-2021 07:44 PM
HI, I'm with problem to get IP by dhcp in my network wireless on AP 1240ag.
I wish that my AP has two VLANs and each VLAN issue IP by DHCP.My DHCP server is a Windows Server 2008 for VLAN 1 and a Linux for VLAN 12.
The AP it's connected by Trunk to a Switch that has the two DHCP Server each one on port Vlan.
but my clients it isn't able get IP address by any each one DHCP server. it's work only with static IP. there is more anything to do in my configuration?
Solved! Go to Solution.
01-28-2011 12:48 PM
1) Are you saying that clients can get a full network connectivity with a static ip on both vlan on your AP ? If that's the case then it looks like the AP is configured fine.
2) What happens if you plug a wired laptop to the switch and configure the port to be in one vlan then the other. Would the PC get an ip address ? If not, then it's a swicthing issue.
01-28-2011 12:48 PM
01-30-2011 06:29 AM
I can't see any IP helper addresses so exactly how are you getting to the DHCP servers?
Any why on earth so many static routes?
02-01-2011 11:08 AM
Thank everyone, I got a document explanations from this community same.so...now all it's working.
08-20-2012 07:09 AM
Sorry I return this issue but how can I delete it from the Forum ?
thanks
