Community Member
Différance between AP 1121g and AP 1131G
I would like to know the difference between an AP 1121G and an AP 1131G.
Thank you
Silver
Re: Différance between AP 1121g and AP 1131G
There are many differences, such as:
1. 1121G has 16MB if RAM, 1131G has 32MB
2. 1131G supports WPA2 authentication, the 1121G does not (though it does support AES encryption)
3. 1131G has a console port, the 1121G does not
4. 1131G is the newer model and will be supported longer by Cisco
However, keep in mind that 1131s normally have two radios. The 1131AG is the standard 1131-series AP, and the 1131G is only really used in countries or environments that ban the use of 5GHz. And even if you are in such a country/environment, the 1131G is a far improved model of the 1121. You should not order 1121s unless you're really looking to save a buck.
Hall of Fame Super Red
Hi Amine,
Just to add a touch to the great tips from Jeff (+5 points for this and for all of your excellent help here Jeff:)
We have many of both the 1121 and 1131 AP's and the 1131 is surely the way to go these days. I'm guessing the End of Life announcement for the 1121's is just around the corner.
Cheers!
Rob
282
