Difference between 12xx and 11xx series?
Hi!
Is there any difference between 1230AG and 1130AG, for example? Besides metal enclosure and dual antenna connectors?
Thanks!
1 REPLY
Hall of Fame Super Red
Re: Difference between 12xx and 11xx series?
Hi Vladislav,
There are other differences between the 1230AG and the 1130AG as shown below. Note the PoE support,memory and Antenna support in particular (the 1130 has built-in antennas). The other important fact is that the 1230 is first generation and is likely to be EoL before the 1130;
Cisco Aironet 1230AG Series Access Point - First-generation dual-band lightweight or autonomous access point with dual-diversity antenna connectors for challenging RF environments
Two high-performance IEEE 802.11a and 802.11g radios offering 108 Mbps of capacity
2.4 and 5 GHz dual-diversity RP-TNC connectors for external antenna support
Available in either a lightweight version or an autonomous version that may be field-upgraded to lightweight operation
Rugged metal case
16 MB of memory with 8 MB of storage
Operating temperature: -4 to 131?F (-20 to 55?C)
Inline power support (Cisco pre-standard)
Console port for management
Support for the Cisco Self-Defending Network, NAC, WPA, and 802.11i/WPA2
Complete with integrated and secure mounting system
UL2043-rated for placement in plenum areas
Cisco Aironet 1130AG Series Access Point - Dual-band lightweight or autonomous access point with integrated antennas for easy deployment in offices and similar RF environments
2.4 and 5 GHz integrated diversity omnidirectional antennas for easy deployment without the need for external antennas
Low-profile plastic case
32 MB of memory with 16 MB of storage
Operating temperature range of 32 to 104?F (0 to 40?C)
Inline power support (Cisco pre-standard and 802.3af)
Integrated and secure mounting system
From this excellent doc;
Cisco Aironet Wireless Access Points Solution Overview
http://www.cisco.com/en/US/products/ps6087/prod_brochure0900aecd8035a015.html
Hope this helps!
Rob
158
