11-17-2013 12:17 AM - edited 07-04-2021 01:16 AM
Now i have wlc5508 with few ap 11xx 12xx in local mode. All work correct. I will have to add few ap1552 in bridge mode ( i have to wait for wlc upgrade to change ap1552 to local mode). My question is that all ( local and bridge mode) will work correct together for my clients: rfid readers, laptop, computer in a,b,g,n mode ? What about roaming and other feature ?
thanks for help
Peter
11-17-2013 01:00 AM
HI Peter,
With 7.2.110.0 you can set the 1550's in local mode:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_2_110_0.html#wp784178
You can use the AP to serve clients by joining it to the WLC, configure it as a RAP and it will provide the clients with wireless traffic on 2.4 GHz band.
I cant say about about roaming feature.......may be someone can elobrate about this.
11-17-2013 11:44 AM
both b and g mode in 2,4 GHz?
11-17-2013 12:10 PM
Yes, 802.11b/g operate in 2.4GHz
802.11a operate in 5GHz
Rasika
11-17-2013 12:12 PM
If you plan on not doing MESH, then you set these 1552's in local mode and they will perform the same tasks as any other AP's in local mode. When you want to do MESH, then that is when bridge mode comes into play and you have to define your RAP's and MAP's.
Roaming, clients devices, doesn't matter if your using local or bridge. roaming depends on your device and coverage and rfid, also depends on triangulation with the coverage you have now.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
