difference between NM-AIR-WLC6 to NM-AIR-WLC6-K9 CARD
Hi Guys
This may be a silly question but I have been having some challanges regarding getting my NM-AIR_WLC6 module to work on my 2811.
I noticed the part number is NM-AIR-WLC6 which is the old cards but will software wise be different from that of the NM-AIR-WLC-K9
This is the second wireless module which i have replaced since the first one gave the same errros but i think this is a software problem since when i loaded the code ,i cannot verify the code but the box runs and detects all.
Strange problem
Kindly  look at status and specs from router
2800LAB#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T17, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 24-Jan-12 07:41 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
2800LAB uptime is 58 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-15.T17.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ0932701R
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Wireless LAN Controller(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
2800LAB#servi
2800LAB#service-module ?
  wlan-controller  cisco Wireless LAN Controller
2800LAB#service-module wla
2800LAB#service-module wlan-controller ?
  <0-2>  wlan-controller interface number
2800LAB#service-module wlan-controller 1/0 ?
  reload      Reload service module
  reset       Hardware reset of Service Module
  session     Service module session
  shutdown    Shutdown service module
  statistics  Service Module Statistics
  status      Service Module Information
2800LAB#service-module wlan-controller 1/0 stat
% Ambiguous command:  "service-module wlan-controller 1/0 stat"
2800LAB#service-module wlan-controller 1/0 status
Service Module is Cisco wlan-controller1/0
Service Module supports session via TTY line 66
Service Module is trying to recover from reset/shutdown
Service Module status is not available
2800LAB#veri
2800LAB#verify c2800nm-advipservicesk9-mz.124-15.T17.bin
Verifying file integrity of flash:c2800nm-advipservicesk9-mz.124-15.T17.bin
Embedded hash not found in file flash:c2800nm-advipservicesk9-mz.124-15.T17.bin.
2800LAB#
398
