yesterday I asked if dipole antennas can be used on the 1262 stand alone APs. The answer is yes but, I was wondering specifically, if the 2.4 AIR-ANT2422DW-R= and the 5.8 AIR-ANT5135DW-R= are compatible with the 1262 AP?
Those would work also.... its really the connection type you need to look for, but all cisco antenas for access points are the same, not including the mesh or bridges.
-Scott *** Please rate helpful posts ***
