Silver
Does the Ethernet ports on the Cisco WLC 2106 works as a switch?
Im new in the wireless field. I have a Cisco WLC 2106 and I got 2 access points working, conected the controller (Aironet 1130AG), but I would like to know if I could connect a host or a laptop to the 2106 WLC.
I have a router conected to the WLC using the port 1, and the APs are in ports 7 and 8, but when I plug a pc in the port number 3, I do not get and IP from DHCP server, (DHCP is giving by the router). Im not sure if the 2106 WLC ports are for connect other network devices like a pc... I would like to know if there is a way to configure the controller to conect a host or a pc to the ethernet ports. thanks for the help...
Posted by WebUser Daniel Nigrinis from Cisco Support Community App
Hall of Fame Super Gold
The data ports of the WLC 2XXX weren't really designed to be connected to WAPs.  It's mostly used for connecting to switches.  It can be done but any issues you will encounter relating to what you're doing will not be supported by TAC, as far as I'm aware.
Hall of Fame Super Silver
Re: Does the Ethernet ports on the Cisco WLC 2106 works as a swi
Leo is right... Of course:)
I tried doing something like this in the past just to see what would happen. Dhcp will only work if the wlc provides dhcp. The wlc will not relay dhcp and it is not a switch/hub. Like Leo mentioned, using the ports other than connecting then to a switch is not supported by TAC.
Scott Fella
Sent from my iPhone
-Scott
Not all the time Scott.  Not all the time.
Highlighted
Well... At least you have good answers:)
Scott Fella
Sent from my iPhone
-Scott
402
