does the wap4410n and the ap541n work together as repeater?
hi,
can you guys please tell me if the two ap´s mentioned above can work together in repeater mode?
had a look in the manuals of both and saw that on the wap4410n you have to enable the repeater mode and enter the mac of the opposed ap.
but on the ap541n it says that no settings have to be made.
anyone knows?
thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: does the wap4410n and the ap541n work together as repeater?
You should be able to if the ap541n is being used as an access point and the wap4410n is set as a repeater.
Scott Fella
Sent from my iPhone
-Scott
I believe that you the wap4410n can be setup as a repeater as long as it connectes to the ap541n not the other way around since the ap541n seems like it doesn't support being a repeater.
-Scott
hi scott,
thanks for the reply.
both ap´s can be run as a repeater, at least according to the manual.
but on the ap541 are no settings necessary and on the wap4410 you have to configure the mac.
i was actually wondering how it works if you dont configure anything on the ap541.
i only now it from netgear, there you have to set both ap´s to repeater mode, is it different with cisco?
florian
Most any devices you need to specify the role that device will be playing. I don't see how a device can be both an ap and then also use it as a repeater without making any configuration changes. On Cisco autonomous AP's there is an option for this setting.
Scott Fella
Sent from my iPhone
-Scott
yeah i know what you mean. i think its really strange too.
but do you think, disregarding from the config, if they both support repeating, respectively both do wds that they can work together as a repeater?
florian
What do you mean work together. If both can support repeater mode, then one would have to be configured as an access point and the other as a repeater.
Scott Fella
Sent from my iPhone
-Scott
i just meant, that i hope even though you dont have to configure anything on the ap541n, that they will work together and not that the ap541 just supports other ap541n in this mode.
that is actually my main question if these 2 ap´s will work with each other.
can i connect the wap4410n as a repeater to the ap541n?
florian
Scott Fella
Sent from my iPhone
-Scott
hi scott,
thanks a lot for your help, really appreciate it!
florian
1053
