%DOT11-2-RADIO_FAILED: Interface Dot11Radio0
Feb 21 08:13:30.958: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station a088.b428.fd00 Reason: Sending station has left the BSS
Feb 21 08:13:31.634: %DOT11-7-AUTH_FAILED: Station a088.b428.fd00 Authentication failed
Feb 21 08:13:31.634: %DOT11-4-MAXRETRIES: Packet to client a088.b428.fd00 reached max retries, removing the client
Feb 21 08:16:28.754: %DOT11-2-RADIO_FAILED: Interface Dot11Radio0, failed - command 16 timeout -Traceback= 0x627C4 0x53BD90 0x807164 0x80A044 0x53B698 0x53CC30 0x1CEDB0 0x1D0B34
Feb 21 08:16:28.754: Writing radio coredump to 'flash:/r0.rcore'
Feb 21 08:16:57.270: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station a088.b457.69a4 Reason: Previous authentication no longer valid
Feb 21 08:36:01.280: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001f.3b72.84b3 Reason: Previous authentication no longer valid
Feb 21 08:44:21.590: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 5894.6b41.6718 Reason: Sending station has left the BSS
Feb 21 12:59:46.226: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001f.3c28.95ac Reason: Sending station has left the BSS
Feb 21 18:25:19.478: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001f.3c28.66c0 Reason: Sending station has left the BSS
Feb 21 18:25:42.530: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Feb 21 18:25:43.530: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
APO01#
Dear all,
I have a wireless network with autonomous AP. That works with WPA2 and Certificates.
All the other Ap works well, but there is one that sometimes drops all the client.
The configuration is identical to the others, but I got the error above and a dump file is written in the flash:
APO01#dir flash
%Error opening flash:/flash (No such file or directory)
APO01#dir flash:
Directory of flash:/
    2  -rwx         195   Feb 9 2012 09:46:48 +01:00  env_vars
    3  -rwx        1089  Jul 25 2011 10:02:30 +01:00  private-config
    4  -rwx        1048  Jul 25 2011 10:02:30 +01:00  private-multiple-fs
    5  drwx         512   Mar 1 2002 01:02:53 +01:00  c1250-k9w7-mx.124-10b.JDA3
  157  -rwx      283999  Jul 22 2011 08:30:52 +01:00  crashinfo_20110722-073052
  158  -rwx        2864  Jul 25 2011 10:02:30 +01:00  config.txt
  159  -rwx         168  Feb 21 2012 09:16:28 +01:00  r0.rcore
Do you have any ideas?
Best regards,
Igor.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
That's an oooold IOS.  Try upgrading the IOS.
Re: %DOT11-2-RADIO_FAILED: Interface Dot11Radio0
Thank you for your reply.
Yes I will try ti update the IOS.
But I think that it doesn't fix the problem, because I have others idenditical AP with the same IOS, and It doesn't have any problem...
Before you upgrade the IOS, can I ask if you can attach a console cable and reboot the WAP?  Post the entire bootup process.
I can not attach the console cable, the WAP is at 6 meters from the floor.
But I have made the IOS upgrade to c1250-k9w7-tar.124-25d.JA1. Now I am waiting to see if the problem is fixed
Hi Leo,
after the IOS upgrade, everything works well.
Best regards,
Igor.
It looks like this is a 1250 series....correct?
If so you may want to try reseating the Dot11radio0 module that it is complaining about as well.
Yes it is 1250.
Before to do the IOS upgrade I have tryed to shut and anable the Dot11radio0 and I got a dump written in the Flash.
Now with the new IOS, it do not happen.
Dear All,
I am waiting that my users work on the Wifi Lan.
I update you as soons as possible.
Best regards,
Igor.
Thanks Igor.
1328
