dot11radio error: encryption mode cipher not configured
on a clean 871w router i want to use wpa encryption on my ssid but on using the the commands to let it work
i get a dot11radio error,
what did i miss
jilles thuis router
beveiligd netwerk
jillesthuis#
jillesthuis#config
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line. End with CNTL/Z.
jillesthuis(config)#interf dot11rad 0
jillesthuis(config-if)#encryptiom mode ciphers tkip
% Invalid input detected at '^' marker.
jillesthuis(config-if)#encryption mode ciphers tkip
jillesthuis(config-if)#ssid notknown
jillesthuis(config-if-ssid)#authentication open
jillesthuis(config-if-ssid)#authentication key-management wpa
Dot11Radio0 Error: Encryption mode cipher is not configured
Re: dot11radio error: encryption mode cipher not configured
Let me know if this works for you:
interface Dot11Radio0
encryption vlan 1 mode ciphers tkip aes-ccmp
dot11 ssid notknown
vlan 1
authentication open
guest-mode
wpa-psk ascii 0 cde456cde4
~JG
Do rate helpful posts
yes it works.
i don't understand why vlan1, it is in the show config connected to the ssid but the routing and ip adresses is going via vlan2 with bv1 ? why ?
i have the wired network connected to vlan1
kan i make vlan1 bridged and delete vlan 2, so that i have one network as is in the more simple routers ?
I have same problem, but when I enter command
I get error: Encryption mode cipher is not configured
But I have (or think I have) configured it. Any ideas what's wrong?
what nowhere is mentioned in the cisco books i read : building a cisco wireless lan and cisco wireless lan security, is that you first must activate the encryption ciphers on the vlan associated to the ssid.
why is that ?
Silver
Ok... so the post I just made here made absolutely no sense after I re-read the original post. Sorry for any confusion (deleting it now).
In your original output it appears as if you are configuring the encryption mode under the radio, you are adding an ssid, and then you are able to configure the ssid?  Something like:
ssid ssid-PSK
    authentication open
    guest-mode
    wpa-psk hex 7
What version of code are you even doing this on?
Because any recent version of code that I'm aware of has moved the SSID configuration outside of the radio, which is like the example provided by the first responder. It would be something like:
dot11 ssid ssid-PSK
    authentication open
    guest-mode
    wpa-psk hex 7
ssid ssid-PSK
The trick here though is that you have to have the encryption ciphers set on the Radio before you can set the ssid to be WPA.... even though in the running-config the ssid comes first....
So back to my point,   I might be completely way of, so just ignore me if I am,  but I wouldn't expect the syntax to be functionally allowing you to configure the ssid under the radio, if it is also allowing you to use the example where its a dot11 ssid SSIDNAME......
19245
