Dot11radio interface down
Hi Experts,
I have a Cisco AIR-AP1252AG-A-K9 access point in autonomous mode on which one of the dot11radio interfaces went down recently. All other interfaces are up. The dot11radio1 interface was in down/down state. I shut / no shut it & its now in up/down state:
Can anyone please help me check why its down?
access-point1#sh ip int brief
Interface                  IP-Address         OK? Method Status                Protocol
BVI1                                  x.y.z.a        YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio1                unassigned      YES NVRAM  up                    down
GigabitEthernet0           unassigned      YES NVRAM  up                    up
I checked the inline power on the switch to which it connects:
access-point1#sh power inline GigabitEthernet 0/33
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi0/33    auto   off        0.0     n/a                 n/a   15.4
Interface  AdminPowerMax   AdminConsumption
             (Watts)           (Watts)
Gi0/33                15.4                 15.4
Currently there are no associations on the AP:
access-point1#sh dot11 associations
access-point1#
FYI:
access-point1#sh version
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(10b)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 30-Jan-08 12:04 by prod_rel_team
ROM: Bootstrap program is C1250 boot loader
BOOTLDR: C1250 Boot Loader (C1250-BOOT-M) Version 12.4(18a)JA1, RELEASE SOFTWARE (fc1)
access-point1 uptime is 1 year, 12 weeks, 3 days, 21 hours, 45 minutes
System restarted at 14:02:43 GMT Fri Oct 12 2012
System image file is "flash:/c1250-k9w7-mx.124-10b.JA1/c1250-k9w7-mx.124-10b.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1252AG-C-K9    (PowerPC 8349) processor (revision C0) with 49142K/16384K bytes of memory.
Processor board ID FGL1502Z0BC
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: E0:5F:B9:9C:A6:1A
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC145229FE
Top Assembly Part Number             : 800-29531-03
Top Assembly Serial Number           : XXXXXXXXXX
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1252AG-C-K9
Configuration register is 0xF
access-point1#sh inv
NAME: "AP1210", DESCR: "Cisco Aironet 1200 Series Access Point"
PID: AIR-AP1252AG-C-K9 , VID: V03, SN: FGL1502Z0BC
NAME: "Dot11Radio0", DESCR: "802.11N 2.4Ghz Radio"
PID: AIR-RM1252G-E-K9  , VID: V01, SN: FOC145157B2
NAME: "Dot11Radio1", DESCR: "802.11N 5Ghz Radio"
PID: AIR-RM1252A-C-K9  , VID: V01, SN: FOC145236NK
  • Getting Started with Wireless
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Dot11radio interface down
Your radio module is failing. I believe your AP is >4 years old.
Sent from Cisco Technical Support Wii App
VIP Purple
Hi pradeep,
Console the AP and reboot it then paste the entire boot process.
Hi everyone,
Thanks for the quick reply. Is there any command output that shows there is a problem?
My company database says this AP is in service since 2 and half years & it has been up running since 1 year 12 weeks...
The serial number you've posted tells me the EXACT AGE of your AP.
So my "method" is far more accurate than your company's asset database.
OMG!!
You are awesome Leo!
So I need to replace this: AIR-RM1252A-C-K9 - the antenna that is down or the entire AP?
Thanks a lot!
I hope your 1250 has maintenance contract.  Because if you RMA your AP you might get UPGRADED to a 1262.
343
