Dot11Radio0 is reset
Anyone know how to rest the Dot11Radio?
I have also try to config the power level but it prompt me that the selection is invalid.
Dot11Radio0 is reset, line protocol is down
Hardware is 802.11G Radio, address is 0000.0000.0000 (bia 0000.0000.0000)
MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/30 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
DOT11-2-RESET_RADIO: Interface Dot11Radio0, Radio won't start, Trying hardware reset on radio
%SYS-3-CPUHOG: Task is running for (1996)msecs, more than (2000)msecs (4/4),process = Dot11 driver.
-Traceback= 23F878 23F860 40AC60 679960 67C634 413FA4 41B2A8 1357B0
%SYS-3-CPUHOG: Task is running for (3995)msecs, more than (2000)msecs (4/4),process = Dot11 driver.
-Traceback= 23F858 23B644 40AC60 679960 67C634 413FA4 41B2A8 1357B0
%SYS-3-CPUHOG: Task is running for (5994)msecs, more than (2000)msecs (5/4),process = Dot11 driver.
-Traceback= 23F860 23B644 40AC60 679960 67C634 413FA4 41B2A8 1357B0
%DOT11-3-POWERS_INVALID: Interface Dot11Radio0, no valid power levels available
Re: Dot11Radio0 is reset
Looks like you could have a hardware issue on that radio, I would send it back to your supplier.
HTH>
do you have a POWER INJECTOR?
If a power-injector is installed, issue the command under CLI:"
"power inline negotiation injector installed"
Best regardas
have you assigned a SSID to the DotRadio0 interface, if not the interface will show a status of reset
The access point already have an SSID. For your info, the access point also support DotRadio 1 for A channel.
The DotRadio 1 does not have this issue and is working fine.
I have tried to type in "power inline negotiation" but the version does not support it.
I guess the card is faulty.
Its not faulty. The IOS upgrade just didn't complete properly. Push IOS to it again and the radio driver will push to the radio. When you reboot you will have a happy AP.
Do you mean that the IOS is corrupt?
Hall of Fame Super Silver
Kian,
It's your configuration that is the issue. I loaded you config that you posted on the other thread:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=Getting%20Started%20with%20Wireless&topicID=.ee7c7c3&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1912b
And I got the same error you are seeing. The interfaces are configured wrong. Make the changes to the configuration and the interface will be up.
-Scott
It still does not help even if i clear and change the configuration. Still receive:
*Mar 1 00:01:53.230: %DOT11-3-POWERS_INVALID: Interface Dot11Radio0, no valid power levels available
*Mar 1 00:01:53.231: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:02:14.362: %DOT11-2-RESET_RADIO: Interface Dot11Radio0, Radio won't start, Trying hardware reset on radio
*Mar 1 00:02:16.360: %SYS-3-CPUHOG: Task is running for (1998)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 23F850 23B644 40AC60 679960 67C634 413FA4 41B2A8 1357B0
*Mar 1 00:02:18.359: %SYS-3-CPUHOG: Task is running for (3997)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 243BF0 23F860 23B644 40AC60 679960 67C634 413FA4 41B2A8 1357B0
*Mar 1 00:02:20.358: %SYS-3-CPUHOG: Task is running for (5996)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 243BE8 23F858 23B644 40AC60 679960 67C634 413FA4 41B2A8 1357B0
*Mar 1 00:02:28.559: %LINK-3-UPDOWN: Interface BVI1, changed state to up
Don't know.... I used your config on an ap I had and I got the same error you are seeing. I adjusted the config and I got it to work... Post the config you have on now.
-Scott
I had the same issue
power inline negotiation prestandard source
solved it
8497
