Downgrade WLC 4.2 to 4.0.219
Hi, Is it straight process for downgrading OS or do I need any intermediary version ?
Thanks for helping
1 REPLY
Hall of Fame Super Silver
Re: Downgrade WLC 4.2 to 4.0.219
4.2 and later code has the configuration in xml, prior versions is in bianary. So if you decide to downgrade to 4.2 to 4.0 then you will have to reconfigure the wlc from the startup wizard and then you can restore the wlc configuration if you had a good backup from that version.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml#t2
-Scott
210
