05-13-2009 12:31 PM - edited 07-03-2021 05:35 PM
we created a dynamic interface on WLC and associated a one ssid using dhcp but this interface do not obtain IP
could you help me to resolve this case on wlc?
regards,
05-13-2009 02:01 PM
Errr ... Dynamic Interface requires STATIC IP Address.
05-13-2009 06:29 PM
the dynamic interface requires static IP address, but the wlan clients can get ip using dhcp server.
05-14-2009 01:39 AM
The dynaminc interface is configure to be static.Then from the GUI goto CONTROLLER----INTERNAL DHCP SERVER----DHCP SCOPE
But the dynamic interface must be in the same ip subnet with the dhcp scope you created. You then need to tie it with the SSID u want. STEP click WLAN-----then the wlan id no---------GENERAL----Inteface u and put the dynamic inteface u just created.
07-29-2009 10:36 AM
I have a similar problem, I have setup one SSID tie to management interface which is configured to using external DHCP server,that works fine. Now I tried to enable a dhcp scope 10.10.10.0/24 on WLC, create dynamic interface 10.10.10.1,and dhcp server point to managment interface, then create another SSID using this dynamic interface, but client can't get ip.
07-29-2009 11:07 AM
Are you pointing to an external DHCP server or a scope internal on the controller?
Do you have DHCP proxy enabled or disabled on the controller?
07-29-2009 12:09 PM
First one points to external dhcp through managment interface, second one to a scope internal on the wlc. DHCP proxy is enabled.
Thanks.
