Dynamic VLAN Assignment with ACS 5.1 and Wireless LAN Controller
     I would like to go for "Dynamic VLAN Assignment with ACS5.1 and Wireless LAN Controler". I want the AP to broadcast only 1 SSID. The  client find the SSID -> Input Credential > RADIUS Authentication > Assign user based on Group Policy.
I try to read the document below.
Dynamic VLAN Assignment with RADIUS Server and Wireless LAN Controller Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml#switch
Controller: Wireless Domain Services Configuration
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c951f.shtml
But it don't work on ACS 5.1. Please advice me about configuration on ACS 5.1.
Re: Dynamic VLAN Assignment with ACS 5.1 and Wireless LAN Contro
From those documents, only the ACS 5.x part is slightly different, however the attributes present on the RADIUS Access-Accept are the same: 64,65,81.
The ACS 5.x has an easy way to achieve dynamic VLAN assignement where you only have to select an Authorization Profile and specify if you want to do VLAN assignment and what VLAN you want. The ACS will then use the needed RADIUS attributes.
Please take a look into the example screenshot attached.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
     I try to debug with command "debug aaa event enable" on WLC that it show information below
*emWeb: Oct 27 02:35:02.992: 34:15:9e:8a:32:ce Override values for station 34:15:9e:8a:32:ce
        source: 48, valid bits: 0x1
            qosLevel: -1, dscp: 0xffffffff, dot1pTag: 0xffffffff, sessionTimeout: -1
*emWeb: Oct 27 02:35:02.992: 34:15:9e:8a:32:ce Override values (cont..) dataAvgC: -1, rTAvgC: -1, dataBurstC: -1, rTimeBurstC: -1
        vlanIfName: '', aclName: ''
*emWeb: Oct 27 02:35:02.992: 34:15:9e:8a:32:ce Inserting new RADIUS override into chain for station 34:15:9e:8a:32:ce
*emWeb: Oct 27 02:35:02.993: 34:15:9e:8a:32:ce Override values for station 34:15:9e:8a:32:ce
*emWeb: Oct 27 02:35:02.993: 34:15:9e:8a:32:ce Override values (cont..) dataAvgC: -1, rTAvgC: -1, dataBurstC: -1, rTimeBurstC: -1
*emWeb: Oct 27 02:35:02.993: 34:15:9e:8a:32:ce Applying override policy from source Override Summation:
And I have some question.
1. Am I must config LEAP for this feature?
2. I cann't configure RADIUS(Airespace). Is it require for this feature?
Regard,
angerninta
1359
