EAP-TLS + WLC 5508 + NPS + AD
elodie.lu
I want to deploy certificates with using EAP-TLS protocole on WLC 5508 and for authentication I'll use NPS (windows microsoft Radius) and Active Directory.
I'm looking for documentation from manufacturer but I found only blogs.
Have you some experiance on this?
Have you any manufacturer documentation?
Scott Fella
You will not find a particular doc that will have the information. You will need to look at blogs and how others have achieved it. It's best to use PEAP and get that working first then implement EAP-TLS. EAP-TLS will require a certificate in each wireless client, so you will need a PKI infrastructure. You would use smartcard or certificate on the policy which would be the only thing in the radius that would change.
Here are some links.
http://networklessons.com/wireless/peap-and-eap-tls-on-server-2008-and-cisco-wlc/
http://www.cisco.com/en/US/products/ps10315/products_configuration_example09186a0080bfb19a.shtml
http://blog.instruosolutions.com/2012/10/10/configuring-microsoft-nps-server-2008-for-wireless-client-authentication-ms-peap/
-Scott
