error in firmware upgrade part 2
I needed to upgrade the IOS on my 350 AP. The upgrade failed in the middle. When I rebooted I noticed that I had an older version and the Aironet Logo was displayed. I resumed the download and it worked this time. I noticed that I could not associate with it so I did some troubleshooting and found that it keeps changing the role in radio network from access point to client. Even in set up when it said Access point if I went to express setup under the role in network it says it is a site survey client and I can't change this. Does anyone know a fix for this.
1 REPLY
Re: error in firmware upgrade part 2
Ensure you are attempting to associate with a valid device. They are:
Access Point to client
Access Point to Access Point (in repeater mode)
Access Point (in repeater mode) to Base Station (in Access Point mode)
Access Point to Workgroup Bridge
If you are connecting to another access point for instance, you will have to be in repeater mode.
241
