Community Member
Error in firmware upgrade
I was upgradeing the firmware in an access point and it failed halfway through. Now I get the following error message. Failed to start driver for port "awc0" (errno=0x006d0002). Is there a way to fix this without sending back to the factory?
1 REPLY
Re: Error in firmware upgrade
The AWCO message occurs when the radio can't be configured.
Let us know which firmware was Access Point was already on and which one you are trying to upgrade to ???
Here is a link which discuss step by step procedure for upgrading firmware for Access Points thru console port..See if that helps..
http://www.cisco.com/warp/public/102/wlan/ap-fw-upgrade.html
Thanks..Tejal
399
