02-13-2012 04:51 PM - edited 07-03-2021 09:34 PM
Hi all
try to setup a LAP for Singapore office, has encounter above errror message.
Following Country codes: AU, KR,NZ,PH,SG has been enalbed in Country Page. the LAP AIR-CAP3502I-S-K9 has been associated with KR intially. We try to change it to SQ, but the error persists. this AP has been setup as HREAP, any suggestion?
Roy
02-14-2012 04:37 AM
Do you still have the AP local to you do you could capture the console output while setting the country?
Steve
02-14-2012 03:35 PM
Yes Stephen, I still have it with me ( in Sydney). I would like to test it before send them to Singapore. should I wait for it to be pluged into Singapore office then configure the contry code?
02-15-2012 04:10 PM
find the answer: disable the access point then it allow country code to be changed.
01-29-2018 05:50 PM
Awesome, that totally worked - thanks for the tip!!
03-02-2018 01:58 AM
Hello Roy,
Error in setting country code -- Wireless Lan Controller
Generally you configure one country code per controller, however WLC code 4.1 onwards allows you to configure up to 20 country codes per controller. This enables you to manage APs in various countries from a single controller. For a given AP all radios should be in same regulatory domain. There is an exception for MESH APs where you have to configure single country code on WLC for them to register.
