Community Member
Error While copy flash IOS from Air-AP1262N-x-k9 to tftp
i want to copy my flast IOS to tftp but when i try to it using tftp following error
Reception#copy flash: tftp:
Source filename [ap3g1-k9w7-mx.124-25d.JA1]?
Address or name of remote host []? 192.168.1.1
Destination filename [ap3g1-k9w7-mx.124-25d.JA1]?
%Error reading flash:/ap3g1-k9w7-mx.124-25d.JA1 (Is a directory)
but i can see IOS file in flash
Reception#sh flash:
Directory of flash:/
    2  -rwx         252   Mar 1 2002 00:00:17 +00:00  env_vars
    3  -rwx        2002  Mar 10 2002 00:01:34 +00:00  config.txt
    4  -rwx          64   Mar 1 2002 00:15:31 +00:00  sensord_CSPRNG1
    5  -rwx          64   Mar 1 2002 00:15:35 +00:00  sensord_CSPRNG0
    6  -rwx           6   Mar 2 2002 00:55:23 +00:00  FOC1620A18W
    8  -rwx        1048  Mar 10 2002 00:01:34 +00:00  private-multiple-fs
    9  -rwx           5  Mar 10 2002 00:01:34 +00:00  private-config
   11  drwx         512   Mar 1 2002 00:13:37 +00:00  ap3g1-k9w7-mx.124-25d.JA1
1 ACCEPTED SOLUTION
VIP Purple
HI Zoheb,
Try like this:
If it is a directory then try something like dir flash:ap3g1-k9w7-mx.124-25d.JA1
and if the dir does show a filename then use the pathname and filename in the more command. something like:
more copy flash: ap3g1-k9w7-mx.124-25d.JA1/ tftp
Give that a try.
VIP Purple
HI Zoheb,
Try like this:
Give that a try.
Bronze
Re: Error While copy flash IOS from Air-AP1262N-x-k9 to tftp
Take a look at the "archive" command to copy the whole dir. in a single .tar archive to the FTP server
Hall of Fame Super Gold
Hold on ... This is not correct.  You are trying to copy a directory folde across.
You need to go into this directory and copy the BIN file into the AP.
349
