Ethernet down on AP1142 (IT IS CONNECTED)
Hello everyone,
This is my 1st ever post to the community.
I have a weird problem.
The set-up is as follows.
WLC 5508 software version 7.0.116.0
DHCP server on windows 2008 R2 (works like a charm, invc. option 43, and 60)
As soon as I connect AP 1142 (the only model I have available) the AP gets an IP address from the DHCP, DHCP gives the controller IP address and AP is joined to the WLC.
But then funny things start to happen (one day after the joining process)
Whenever I come back the next day the AP is not appearing on the WLC (this is the case with 3-4 AP's different AP's)
Now, I consoled to the AP and I want to share the log with you. It seems that there is something wrong with the Ethernet port of the AP.
AP2894.0fc9.2ea4#reload
Proceed with reload? [confirm]
Writing out the event log to nvram...
*Mar  1 00:27:22.896: %SYS-5-RELOAD: Reload requested by Cisco on console. Reload Reason: Reload Command.
*Mar  1 00:27:22.896: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
*Mar  1 00:27:27.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
using  eeprom values
WRDTR,CLKTR: 0x87000800 0x40000000
RQDC ,RFDC : 0x80000034 0x00000206
using ÿÿÿÿ ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x87000800, 0x40000000
RQDC, RFDC : 0x80000034, 0x00000206
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 28 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7457792
flashfs[0]: Bytes available: 24927232
flashfs[0]: flashfs fsck took 20 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 28:94:0f:c9:2e:a4
Waiting for PHY auto negotiation to complete... TIMEOUT !
Ethernet link is down.
The system has encountered an error initializing
the Ethernet port.
The system is ignoring the error and continuing to boot.
If you abort the system boot process, the following
commands will re-initialize Ethernet, TFTP, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
Loading "flash:/c1140-k9w8-mx.124-23c.JA2/c1140-k9w8-mx.124-23c.JA2"...################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w8-mx.124-23c.JA2/c1140-k9w8-mx.124-23c.JA2" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 12:50 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 28 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7457792
flashfs[1]: Bytes available: 24669184
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0  present 8363 8000 90020000 0 90030000 B
Radio1  present 8363 8000 98020000 0 98030000 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-E-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1552Z3P9
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 7.0.116.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 28:94:0F:C9:2E:A4
Part Number                          : 73-12836-04
PCA Assembly Number                  : 800-33767-04
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15500UBE
Top Assembly Part Number             : 800-33775-03
Top Assembly Serial Number           : FCZ1552Z3P9
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:07.934: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.945: *** CRASH_LOG = YES
Security Core found.
Base Ethernet MAC address: 28:94:0F:C9:2E:A4
*Mar  1 00:00:50.171: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:50.172: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:50.742: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:50.792: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:50.815:  status of voice_diag_test from WLC is false
*Mar  1 00:00:52.971: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:52.971: %SNMP-5-COLDSTART: SNMP agent on host AP2894.0fc9.2ea4 is undergoing a cold start
*Mar  1 00:12:58.042: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:12:58.103: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:12:58.113: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:12:58.113: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:12:58.129: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:12:58.144: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Mar  1 00:12:58.155: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:12:58.954: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:12:59.113: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:12:59.113: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:12:59.635: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:12:59.831: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:12:59.963: Interface Dot11Radio1 transmit power indices set/txp_pndg cleared
*Mar  1 00:12:59.987: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:13:00.831: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:13:16.918:  status of voice_diag_test from WLC is false
*Mar  1 00:13:16.975: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:13:27.001: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:13:28.001: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:13:37.001: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:13:47.001: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:13:57.001: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:14:07.001: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:14:17.001: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:14:17.001: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:14:27.006: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:14:37.006: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:14:47.006: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:14:57.006: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:15:07.006: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:15:07.006: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
It says on RED that the ethernet link is down but just one day prior to that through the same port it joined the WLC.
As I've said it happens to all the AP's I connected so far.
Here's an output from 'show ip int brief' command:
AP2894.0fc9.2ea4#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      NO  unset  up                    up
Dot11Radio1                unassigned      NO  unset  up                    up
GigabitEthernet0           unassigned      YES other  up                    down
I would really much appreciate your help.
Thank you in advance,
Albert
  • Getting Started with Wireless
2 ACCEPTED SOLUTIONS
VIP Purple
HI Albert,
Can you check the port where your AP connected ??
Its look more like the port setting on switch and AP port.
Check the setting and make it speed 100 and duplex full on both side.
Switch:
Config t
int fa0/15
speed 100
duplex full
switch port access vlan xx
switch mode access
AP:
Config t
interface FastEthernet0
speed 100
full-duplex
Dont forget to rate helpful posts
Hall of Fame Super Gold
Post the output to the command "sh interface G0".
What model is the switch connected to the AP?  If it's a Cisco, can you state the complete model number?
VIP Purple
HI Albert,
Switch:
Config t
int fa0/15
speed 100
duplex full
switch mode access
AP:
Config t
speed 100
full-duplex
Hello sandeepchoudhary21,
I figured it out that the port on the gigabit switch was set to Auto and since the AP has the Gb capability it established the communication on the same level (Gb).
Before Cisco Support Community approved my I did the changes as you proposed and works perfectly now.
It was killing me for few days now.
Thank you for you answer and thank you for your fast reply.
Just one small difference from your proposal.
AP ethernet port is configured through the WLC with command:
(Cisco Controller) config>ap ethernet duplex full speed 100 all
Thanks again,
Albert
148
