External antenna for WLAN Client Cardbus adapter
hallo
is it possible to connect an external antenna to a wlan cardbus adapter like AIR-CB21AG-E-K9 ?
The data-sheet reports "Antenna: Integrated dual-band 2.4/5-GHz, 1-dBi, effective-gain antenna on a two-
meter cable"
I don't see an antenna connector on the adapter and I don't find any antenna cable adapter to connect an antenna !!
Can you help me ?
best regards
francesco
Hall of Fame Super Silver
Re: External antenna for WLAN Client Cardbus adapter
What I have heard is that you would have to peel off the top "Sticker"..... you know the black thing that say's Cisco peel that off and it will expose the connector.
-Scott
Wow, you're right.
I used this card for about 2 years and didn't know that, nice.
Yeah.... me too. They should of worked around that connector.
-Scott
hallo
are you sure that peeling off the black sticker we don't break the adapter ?
which kind of cable adapter we need to collegue an external antenna ?
is there a conversion kit from cisco ?
best regards
francesco
199
