External Antennas with 2602
Hi all,
I have a requirement in which i need to cover large plain areas with high gain omnidirectional antennas.
Initially we used to suggest 1261 Aps ( single band  , as the end user devices are predominantly 2.4ghz Barcode Scanners) along with 5 dbi AIR-ANT1728 antennas.
Now as i understand 1260s are Approaching end of sale , and the substitute product is 2602e series. But i am confused as to which external 5 dbi antenna (omnidirectional ) to suggest in place of air-ant1728 as i cannot find any suitable antenna in the 2600 section  in the antenna portfolio document below..
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
Please advice as to which antenna i should be using with 2600e series.
Thanks in advance.
  • Getting Started with Wireless
1 ACCEPTED SOLUTION
Best bet would be the AIR-ANT2544V4M-R=  it's the closest from Cisco's antenna list.
or
this guy from Terrawave
http://www.terra-wave.com/shop/80211n-245-ghz-6-dbi-mimo-outdoor-omnidirectional-antenna-with-rptnc-plug-connector-p-918.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
1 REPLY
or
HTH,
Steve
490
