12-03-2013 10:02 AM - edited 07-04-2021 01:21 AM
In which situation you'd recommend external dipole antennas with 2602AP?
Vin
Solved! Go to Solution.
12-05-2013 10:27 AM
Thats a great question. I too had a similar question based on internal or external when both antennas are rated the same or very similar. Here is how I look at it ..
When you purchase an access point to allow external antennas it gives you the ability to shape the signal. if you need to shape the signal in a specific direction to lessen co-channel interference external antennas are your ticket. Or perhaps you have a need to strengthen the signal with passive gain by adding a strong antenna.
If you purchase an external ap and put the same rated antennas as an internal ap what do you really gain ? Nothing if you ask me other than future flexibility.
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
12-03-2013 10:33 AM
Depends on what you are doing. Genearlly if you are just mounting to regular 10' high ceilings I wouldn't go external. I'd start looking external if you're up around the 20'+ area
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
12-03-2013 10:36 AM
Ok, so basically the main advantage is for high ceiling areas? Can you explain the reason please?
Vin
12-03-2013 10:38 AM
a standard 2.2dBi external antenna has the same pattern as the internal, so unless you need to use higher gain antennas I don't really see the need to go external.
HTH,
Steve
12-03-2013 11:04 AM
12-03-2013 01:48 PM
Maybe you should tell us what you are trying to achieve. Cisco doesn't have any dual-band dipoles (aka "Disco Sticks") available for 1600, 2600, 3600 & 3700 APs yet.
12-03-2013 02:08 PM
Leo,
There are rubber duckies for dual band
AIR-ANT2524DB-R=
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
But again, unless you need a higher gain I just do't see the point in going with external antenna.
HTH,
Steve
12-03-2013 02:59 PM
I thought the OP wanted the Disco Sticks.
12-05-2013 09:57 AM
This was a general question, there is no specific case. I think that the question was quite clear, basically I'd like to understand if there is any specific case when you'd use external dipole antennas (such as AIR-ANT2524DB-R= ) instead of embedded ones.
12-05-2013 10:27 AM
12-09-2013 07:39 AM
Thank you George.
12-05-2013 11:33 AM
The antenna you've choosen has the same power as the ones with internal antenna. The only difference between the two APs is the cost. The AP with external antenna is cheaper but this is because the antenna is not factored into the cost. All in all, if you want to use the low power antenna, use the AP with internal antenna unless you want to future proof.
Sent from Cisco Technical Support Nintendo App
12-05-2013 11:36 AM
The price difference is only a few dollars, the cost of the dipoles .. lol
12-05-2013 01:40 PM
That's true, George.
