Community Member
Flex AP with strange EVT-5-NTC d0 Beacon events
Hello Support Community,
I am experiencing some strange behaviour with an AIR-LAP1142N-E-K9.
It is running with CAPWAP on a CT5508. Firmware; 7.4.110.0
It is one of many FLEX APs on that controller and I havent seen this behaviour on any other yet.
The user on site have a very slow connection process. It can take up to 45 minutes untill they actually connect.
The AP log shows alot of this:
(controller) >show ap eventlog ulmipap01
AP event log download has been initiated
Waiting for download to complete
AP event log download completed.
======================= AP Event log Contents =====================
Feb 17 12:16:26.176: %EVT-5-NTC:
d0 Beacons set state ds 2020105 0 1 0 0 0
Feb 17 12:16:26.211: %EVT-5-NTC:
d1 Beacons set state ds 2020105 0 1 0 0 0
Feb 17 12:16:26.212: %EVT-5-NTC:
Feb 17 12:16:26.301: %EVT-5-NTC:
Feb 17 12:16:26.394: %EVT-5-NTC:
Feb 17 12:16:26.510: %EVT-5-NTC:
I could not find any reasonable explainations of this message. Surprisingly google also hasn't seen this particular event message yet.
Before you ask: Link Latency is fine for the most part:
Current (mSec) Minimum (mSec) Maximum (mSec)
Link Latency6
24
214
Data Latency<1 <1
<1
And help is greatly appreciated.
Hall of Fame Super Silver
Re: Flex AP with strange EVT-5-NTC d0 Beacon events
Couple questions... Is this happening on all AP's at that site or just one? Are all users being affected or just one? Is it a specific device type that's having issues?
-Scott
Community Member
Hello Scott,
device type AP: AIR-LAP1142N-E-K9
device type Clients: Notebooks
The location only has the one AP.
Further event entries:
Feb 17 14:30:03.596: %EVT-5-NTC_PROC: dot11_return_serving_channel: d1 Channel 36
Process: Dot11 driver
Feb 17 14:30:17.091: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
The d0 and d1 in the aforementioned seem to refer to 2.4 and 5 GHz radio.
Thats still not enough information to help.... what other log info are you seeing from the WLC?  Is iphones and android devices working fine?
Post the following:
show sysinfo
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Community Member
At the moment the user tell me the connectivity looks good.
But there are still those %EVT-5-NTC eventlogs on the AP every few milliseconds.
(controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... hdhi402a0ws01
System Location..................................
System Contact................................... **************
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... ***.***.***.***
Last Reset....................................... Power on reset
System Up Time................................... 2 days 0 hrs 46 mins 35 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... DE  - Germany
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +24 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 6
Number of Active Clients......................... 1285
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 44:D3:CA:B7:5E:A0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 250
When you say "other log info  from the wlc" do you mean something specific? I have about 1000 clients  on it. So there are quite alot of syslog messages going around.
Just wanted to see if you see any general logs, but with that many clients it would be tough.  The AP is joined to the WLC and is serving clients or not?  Is the radios on the AP's enabled?
config 802.11a enable network
config 802.11b enable network
Scott
-Scott
Community Member
... I'm going to open a TAC.
Community Member
Hello, did you solve this
Hello, did you solve this issue? how? thanks in advance.
Community Member
Hello Martin,sorry for the
Hello Martin,
sorry for the long wait.
No I didnt solve it. Which means AP logs are completely useless for me atm, as most (if not all) of my APs with 7.4.* spam those messages all day, every day.
If I remember correctly, the TAC response was something like "oh well, sorry about that."
I hope they fix it with a future 7.4 patch.
398
