01-20-2014 08:49 AM - edited 07-05-2021 12:00 AM
I am curious if this has been tried before.
If ip helper address is used on the gateway interface for the AP management network, and points to the WLC that is serving the IP's, does the WLC send Option 43 to the AP's? I have been setting up local DHCP pools on the routers for each location, but haven't tried to forward the DHCP requests to the WLC in this type of setup where the WLC is colocated centrally from all the sites.
01-20-2014 08:59 AM
The WLC when used as a dhcp server doesn't send Option 43. If you are trying to use ip helper
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-20-2014 09:02 AM
OK I will give that a try. Should be much easier than figuring out the HEX. Not that I can't do it, I just dont do it enough.
01-20-2014 09:04 AM
That is how I do it.... I will remove that ip forward protocol after I'm done unless my customers wnat to keep it.
Scott
01-20-2014 09:17 AM
Just to add... Steve also reminded me of UDP 5246 & 5247 if your AP's are CAPWAP:)
Scott
01-20-2014 09:20 AM
The WLC in question is a 4402 dinosaur, does that matter? It has code 6.0.199.
01-20-2014 09:23 AM
No... Just use UDP 12222 and 12223
