10-23-2013 03:33 AM - edited 07-04-2021 01:08 AM
In a Flexconect deployment can we have unique SSIDs configured for the remote offices.The objective is to prevent remote office users from being asscoiated with the Central Site SSIDs(dont want central site SSIDs being propagated to the remote SSIDs).This is possible in Aruba.Is it supported in Cisco and how do we enable the same
Sumesh
Solved! Go to Solution.
10-23-2013 04:42 AM
Yes this is possible by using AP Groups. AP Groups allow you to create unique groups that you place access points in. Then you also have the ability to configure what SSID's is part of that AP Group. Here is a link:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
10-23-2013 04:42 AM
10-23-2013 01:41 PM
Agree with Scott, you can do that via AP group.
Here is a very good CiscoLive material which gives you all the features supported in FlexConnect design. This should provide you answer if you have more queries on this FlexConnect design/Features.
Rasika
**** Pls rate all useful responses ****
