Guest Anchor - Web Passthrough - Apple device web redirect issue
Hi All,
I've setup a Guest Mobility Anchor at DMZ with 5508 WLC. I've setup the EoIP mobility tunnel and everything works so far.
Now, I was testing multiple clients to connect to the Guest SSID and observed that Apple devices are not redirecting url, resulting unsuccessful connection.
I looked Cisco docs and added the command "config network web-auth captive-bypass enable" on the Anchor as recommended.
Even after executing the command, I'm still facing web redirect issue with Apple Devices. I don't have any issues with other devices, except Apple.
My controller running code AirOS 7.6.130.0. I'm using DMZ controller as DHCP server for Guests and public DNS servers as 8.8.8.8 & 8.8.4.4
How to solve this web redirect issue? Will a Third-party generated CSR solves the problem?
CJ
Hi, What is the exact issue ?
What is the exact issue ? Is it not happening automatic or not happening even after opening Safari and trying to type http://1.2.3.4
Dhiresh
Hi All,The issue was with
Hi All,
The issue was with WISPr Protocol with iOS Clients. After upgrading the AirOS Code on the controller to 8.0.100.0; the issue with Web Redirect is resolved.
Jagan
Hi, are youre Apple Devices
are youre Apple Devices running on IOS Version 8.x?
If it is, then I think you have this problem!
https://discussions.apple.com/thread/6555023
Best Regards,
Mario
There is a bug in certain
There is a bug in certain apple devices with certain levels of codes.
It still should re direct when type in a webpage or the virtual IP address.
193
