Guest data switching from 8510 controller for multiple branch sites.
ammahend
I have many sites all in Flexconnect, controller by 8510 controller, is it possible for GUEST to do central data switching.
I know authentication can be done centrally.
Thank you
-hope this helps-
if you're going to centralize the data of the Guest, then the remote site VLAN doesn't matter. The traffic will be sent across the CAPWAP tunnel to the WLC and ingress/egress there. So you only need to define the interface on the SSID, to whichever interface is the guest VLAN.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
15 Replies 15
Stephen Rodriguez
Yes, you can centralize the data usage of the Guest WLAN. Under the WLAN don't check the FlexConnect enabled box.
HTH,
Steve
HTH,
Steve
will it work even if the AP is in hreap mode ??
-hope this helps-
yes sir, it will
HTH,
Steve
I might have some something wrong with my testing then, I will test again, I put a post last week that was not about GUEST but about normal DATA WLAN and i think someone replied it can't be done.
-hope this helps-
That was me.
But the Guest would be one VLAN, for all sites, which is different from that post
Steve
HTH,
Steve
right,  guest would be one vlan say vlan 10 for all sites but since each site is seperate by L3 link, each site would have a different subnet for that Vlan 10, so on the controller, which interface subnet would I tie the GUEST ssid with ??
If i don't care about subnet, and on controller maps guest to subnet say 10.10.10.0/24 then it gets locally switches and School 1 guest users get an IP 10.10.10.1 and school 2 guest user gets an IP 10.10.10.2, which creates routing challenge.
-hope this helps-
HTH,
Steve
HTH,
Steve
Thanks for the reply.
-hope this helps-
you know I am still seeing the same issue, with AP in flex connect mode and WLAN not enabled for local switching it does not even show up the SSID, may be its a bug I am using old gear to test this out, but I will test this on new gear.
-hope this helps-
do you have AP groups enabled?
HTH,
Steve
what I have is below :
USER---AP---SW---ROUTER1----WAN---ROUTER2----SW---CONTROLLER
AP in Hreap, ssid GUEST , wlan id 17, mapped to interface 10.10.10.1 in vlan 10, gateway is router1 which is 10.10.10.100. router 1 is also DHCP server, WLAN is not enabled for local switching.
I don't see the SSID.
no AP groups.
-hope this helps-
sorry typo router 2 is gateway and router 2 is dhcp.
-hope this helps-
 Guest is wlan id 17.
You have to use AP group to get a WLAN above 16 to show on an AP.
Steve
HTH,
Steve
this was the last post.
https://supportforums.cisco.com/discussion/12192231/centralized-multiple-sites
-hope this helps-
