Guest wireless routed to a different ISP?
We have a a 4402 with several WLANs including a Guest WLAN. Is it possible to route all traffic from the Guest WLAN to a separate ISP? Guest is setup on a different VLAN. Would this be configured in the 4402, the switches, or our ASA device?
Thanks in advance for your help.
JK
2 ACCEPTED SOLUTIONS
Re: Guest wireless routed to a different ISP?
On the controller, I would send the guests to a specific interface, which is a specific VLAN/subnet. Then I would route this subnet to the second ISP from your router or layer 3 switch...
hth
Jerome
Hall of Fame Super Silver
Jerome is right, or else you can disable LAG and configure port 1 as the management and ap-manager and connect that to you infrastructure and then assing the ssid to port 2 which will be connected to a switch with your other isp or dsl connection.
-Scott
hth
Jerome
-Scott
162
