Guest wireless solution needed, Please Help
Hello everybody
Ok, we have an issue in our company with guest wireless. We have lots a sites that have the requirement, from 4 users to maybe 100 or so that need guest access.
The issue is that each site has its own internet connection that we want to use for guest wireless, we dont want the guest traffic coming to our HQ.
On each site we have a firewall, and some wireless access points, some sites have controllers, some have autonomous access points.
We need a way to authenticate all the guest network on all sites so a user can create a username and password, and they get a splash page.
Is there any solution what can do this at all?
cheers
Carl
Hall of Fame Super Silver
Re: Guest wireless solution needed, Please Help
You can do this with sites that has a wlc, but with sites that have autonomous APs, you will need to find a 3rd party web hosting software to accomplish this.
You might want to see if you can convert those autonomous APs to h-reap/FlexConnect and you should be able to use WLC's from other sites. I don't know if this is possible, but it depends on you APs and really your wan link.
-Scott
Bronze
For the site where you have LWAPP units and using WLCs you can setup anchor and foreign WLC setup.
http://www.cisco.com/en/US/docs/wireless/technology/guest_access/technical/reference/4.1/GAccess_41.html
For the standalone you will need to use a 3rd party application or software.
467
