11-08-2007 08:10 PM - edited 07-03-2021 02:55 PM
Can someone exactly clarify the mechanisam involved in guest accessing Internet ?
How does he ge automatically get the config parameters such as proxy address atc ?
Solved! Go to Solution.
11-10-2007 07:33 AM
"It Depends" to use a quote from Neil Reid. You can configure guest access several ways. The mobility controller anchor methd is one of the most commonly used. This requires you to configure a guest ssid that utilizes a mobility anchor controller that resides outside the firewall. The traffic on this ssid is tunneled to the mobility anchor controller on an EoIP tunnel. Refer to the Mobility Anchor Configuration guide
Yes, this requires a dedicated controller but is the most effective method.
11-10-2007 07:33 AM
11-12-2007 06:21 AM
Proxy can be pushed down via dhcp option. Guest access however will not work if proxy is configured. Users will not get a login page.... they will have to turn off proxy and then open a browser to get the login page. Login to the network or hit accept and then the user will have to turn on proxy. No work around yet.
